Meth tank time limit.
Old Feb 24, 2007 | 03:01 AM
blackonblackevo's Avatar
Arrow Meth tank time limit.
Hey evo owners how long does a 2qt tank of meth last you with a gt35r kit on the evo, while racing? For example would you be able to fill up your gas tank twice before the 2qt would run out?
Old Feb 24, 2007 | 04:06 AM
4TUN8's Avatar
with a half gallon? If you're running a 7gph nozzle I would assume it would only last one gas tank.
Old Feb 24, 2007 | 06:28 PM
That sucks, what size tank would you recommend for 2-3 tank fulls of gas.
Old Feb 24, 2007 | 06:50 PM
4TUN8's Avatar
1 gallon
Old Feb 24, 2007 | 07:11 PM
are one of those wiper fluid tanks that come on the evo 1 gallon.
Old Feb 25, 2007 | 03:00 AM
4TUN8's Avatar
You should look into buschur's smc alky kit, it comes with a tank and works very well, I run it personally.
Old Feb 27, 2007 | 09:53 AM
Paul Nelson's Avatar
I'm running a 3 gallon tank from summit racing works awesome.
Old Feb 27, 2007 | 09:59 AM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
I'm not really experienced with alky systems but in theory...actually in general...is there any reason why you couldn't get just a small fuel cell for your alky kit?
Old Feb 27, 2007 | 10:58 AM
joeMama's Avatar
SMC makes a kit with a trunk mounted bottle. The bottle under the hood is smaller, but I think it hold more then 2 quarts. I have an '04 so mine is in the I/C Spray tank
Old Feb 28, 2007 | 04:42 PM
SlowCar's Avatar
there are many factors:
-your nozzle size
-how often you are above the trigger point
-how long you stay above the trigger point
-whether your system is a on/off or progressive
Old Feb 28, 2007 | 04:45 PM
SlowCar's Avatar
I run twin 5 quart tanks and it contains 8 mins worth of methanol if i say at 10psig and above.
Old Feb 28, 2007 | 04:51 PM
Ultimate CC's Avatar
use your stock washer tank and call it a day...
Old Feb 28, 2007 | 04:55 PM
SlowCar's Avatar
GT35r....if it is a 15GPH nozzle......stock washer tank will be empty in no time
Old Feb 28, 2007 | 05:00 PM
SlowCar's Avatar
the stock washer tank = 3200cc
15gph nozzle = 945cc/min
3200/945 = 3.38mins spray time
its over a gallon and with mine setup on 625 nozzle its lasts a good amount of time even on nitrous...he also never specified which type of racing he intends to use this for, of course if he is going to road race I would suggest a larger tank for sure...
