What are damages to the engine?
Old Mar 16, 2007 | 01:34 AM
nimanos's Avatar
Is it true that using water/meth can cause internal parts to wear out faster and cause failure?
any experiences?
if yes?
on what kit and waht percentage?
Old Mar 16, 2007 | 01:46 AM
LoRo's Avatar
I personally wouldn't run water or meth in a Daily Driver... but some may be crazy enough to do so.
Old Mar 16, 2007 | 01:48 AM
AlohaEvo's Avatar
why not? I'd say most of us that run alky are on our DD's
Old Mar 16, 2007 | 05:21 AM
Planet Evo's Avatar
No
Old Mar 16, 2007 | 03:38 PM
nimanos's Avatar
what about emptying the meth
so should i just live meth in the tank for a Daily Driver and use it on a progressive kit like the AMS one
Old Mar 17, 2007 | 04:12 AM
SlowCar's Avatar
any experiences?
if yes?
going fast cause $...parts will wear out and break due to increased stresses
-run a constant pressure system so that you get optimal atomization@all time
-run a solenoid valved system so that injection will start/stop when it is supposed to
Old Mar 17, 2007 | 05:20 AM
nimanos's Avatar
which
do you know any package from any company that has those properties you mentioned?
Old Mar 17, 2007 | 10:23 AM
SlowCar's Avatar
for ~$500, you can run the basic, very cost effective boost triggered aquamist system (150W aquamist/shurflo 125psig by-pass pump + aquamist dds3 failsafe + solenoid valve) - simple yet surpassing in performance to any progressive systems currently available
https://www.evolutionm.net/forums/sh...36&postcount=4
you can upgrade the the above system to the HFS-5 later if you wish to the ultimate in alky injection by the addition of the fuel injection amplifier and the amazing High Speed Valve.
https://www.evolutionm.net/forums/sh...53&postcount=1
Old Mar 17, 2007 | 03:21 PM
nimanos's Avatar
great
thanks man
