Looking for a Meth Tank
Old Apr 10, 2007 | 06:56 AM
yoyo6999's Avatar
HEY just need some help finding a good tank for my new system
Old Apr 10, 2007 | 07:05 AM
SlowCar's Avatar
http://fluids.flambeau.com/
http://www.usplastic.com/catalog/pro...uct%5Fid=14120
Old Apr 10, 2007 | 07:15 AM
Ryu123's Avatar
Thank you so much . Exactly what I was looking for also.
Old Apr 10, 2007 | 07:23 AM
SlowCar's Avatar
i am using the flambeau tanks
the US plastic corp tanks are cheap, dont know if they are of the same quality of flambeaus
Old Apr 10, 2007 | 07:26 AM
SlowCar's Avatar
Old Apr 10, 2007 | 07:27 AM
yoyo6999's Avatar
so do i get a cap that is vented from the top or threaded vented
Old Apr 10, 2007 | 07:30 AM
SlowCar's Avatar
i went with the flambeau threaded vent - didnt want any dust to get into the tanks
Old Apr 10, 2007 | 06:32 PM
Ryu123's Avatar
SlowCar, are there any connectors needed for the tank or does the Aquamist HFS-1 comes complete with everything except for the tank? Trying to get all the parts before I attempt the install. Thanks.
Old Apr 11, 2007 | 05:24 AM
SlowCar's Avatar
Ryu123:all you need is a tank
Old Apr 19, 2007 | 06:01 AM
Levar's Avatar
Veteran: Army
Originally Posted by SlowCar
Man. I have to say that your set-up is very impressive. I've never seen it done like that before. Two questions: 1. Do the tanks come with the mounting brackets? 2. Did you use anything to mount the tanks and the pumps to?
Old Apr 19, 2007 | 06:39 AM
SlowCar's Avatar
Hi there, these are the tanks i got, its got mounting holes on each side of the tank:
http://fluids.flambeau.com/standard_...5.0_quart.html - Item # 062100
The tanks and pump are mounted on 2 aluminum strips bolted to the V brace behind the seat:
Old Apr 21, 2007 | 08:03 AM
Levar's Avatar
Veteran: Army
Awesome! I think your set-up is nice and clean. The only concern that I would have is do you have any problems in keeping a nice flow to the injector given the distance between the pump? I read that it's not recommended to have a long distance on one of the alcohol injection websites.
Old Apr 21, 2007 | 12:51 PM
SlowCar's Avatar
on my aquamist HFS-1 system, the flow sensor shows that once the boost trigger point (10psig) is reach, there is ~1000cc/min methanol flowing from the pump in the trunk to the 2 jets in the UICP. There is no issues of not flowing enough.
