Gb Hfs-1
Ok, heres two images of the tank. I included the pump in the images to help with size reference. Please forgive my photography skills, I do not have Richard's talents with this stuff and I'm in a little bit of a hurry to get some other stuff done today.
If anyone has an suggestions for another image....such as angle or close up please let me know.
OK, this post is for those people looking at the upgrade pricing.
First the price of the HFS-5 is $895.00. Second the price of the HFS-1 is $650.00. The cost to a user to upgrade from a HFS-1 to a HFS-5, is the difference between the two prices.
HFS-1 to HFS-5 upgrade = $245.00.
The upgrade kits will only be available directly through Aquamist. This upgrade will not be available through resellers.
Thanks
https://www.evolutionm.net/forums/sh...8&postcount=40
The main differences between the two systems:
1) Single stage and progressive with fuel flow
2) Inline valve: on/off (standard speed valve) vs PWM (High Speed valve)
3) Comes with a 22cc surge arrestor/accumulator (HFS-5)
The similarity between the two:
4) 150W/125psi shurflo pump
5) DDS3-v8 fail-safe flow monitoring system (with dash gauge)
6) All necessary fittings and wire harness
7) Neither system comes with a tank
8) Three jets + 2x Nickel plated Brass hard pipe adaptor
9) Y-piece for twin jet operations.
10) 100 micron inline fliter
HFS-1 to HFS-5 upgrade path.
Online readings:
https://www.evolutionm.net/forums/sh...d.php?t=263787 (HFS-5)
https://www.evolutionm.net/forums/sh...d.php?t=259743 (HFS-5 - insight into the design)
Detailed Installation:
http://www.srtforums.com/forums/showthread.php?t=338924 (HFS-5 on SRT4)
http://www.srtforums.com/forums/showthread.php?t=334573 (HFS-5 on SRT4)
As the HFS-1 is not yet shipped: the following link is the best representation:
https://www.evolutionm.net/forums/sh...d.php?t=239686 (HFS-1)
Online readings:
IMO get and use the HFS-1, learn W/A and enjoy, if at anytime in the future you want to upgrade to the most advanced W/A on the market for what ever reason you can.
If you want the HFS-5 now, I see nothing wrong with getting the HFS-1 through the GB and then asking for upgrade at the same time so that you can save money.
You more or less can not lose since you will be paying less money for either kit then you will find again at a later date.
