water and meth mix???
Old Jun 22, 2007 | 05:17 AM
chuntington101's Avatar
whats everyones oppinions on a water/meth mix injection??? i read an article on WW2 fighters used for the air races. they said that they ditched the aftercoolers and ran pure water/meth mix to cool the intake/reduce dept.
wondered whats the feeling is about the stuff some 60 years on.
thanks Chris.
Old Jun 22, 2007 | 06:42 AM
SlowCar's Avatar
i wanted to try going intercoolerless early this year...but got too busy with work
https://www.evolutionm.net/forums/sh...rcooler+delete
and i might need more tank volume than 10 quarts
Old Jun 26, 2007 | 11:54 PM
have you thought about going for a chargecooler setup??? i have sene quiet a few drasg evos running it. works really good! the domestic guys love it to!
where you just going to pray meth or meht nad water???
Chris.
Old Jun 28, 2007 | 06:54 PM
bnice01's Avatar
it all depends on your setup and what your overall goal is.
I run 100% but try to make my timing agressive as possible but still safe.
Do you want just a cooling factor?
Use it as 5th injector?
What turbo are you running?
How big of nozzle are you running?
Just a few ?'s
Old Jun 29, 2007 | 08:03 AM
Just a few ?'s
im just trying to compear them both like for like. wondering which will be the best overall.
Chris.
Old Jun 30, 2007 | 05:17 AM
bnice01's Avatar
100 % for me work best for both cars i had w/i on. but my last car timing was really high, i had an aftermarket turbo, no way of controlling timing, and more meth keep knock count to 0-2.
Just start out with a 50/50 mix, then the next time try 75/25 (meth/water), and continue that. the best judge is yourself and everyone car will response to differently to different mixes living enviroment is one reason why & plus your setup is another reason. you can even try 100% distill water. i hope that helps.
me-var
Oct 25, 2015 02:21 PM
kevness
Oct 2, 2013 04:07 PM
shaman
Aug 29, 2012 12:06 AM
tephra
Sep 14, 2009 07:15 PM
95nracer
European Forum
17
May 21, 2008 12:53 PM
