ethanol injection
Old Jul 31, 2007 | 10:25 AM
94AWDcoupe's Avatar
Originally Posted by KevinD
sense i have first hand experience using a 5th injector injecting E-85, yes i know it works. it will also work with meth if your lines are alcohol compatable. although it sounds like fun, i think you are just reinventing the wheel. no system is going to be as reliable as the stock system. even if you use all OEM parts, your wiring may not be to par, the mount of the injector might fail... etc etc. point is, if you are planning on running a second fueling system to run higher boost, you are going to want some kind of fail safe.
the 5th injector we used on our race car took its fuel from the fuel rail so it used the same pump the primary injectors used. it even used the same fuel (it was a turbo E85 car with 5 injectors). the 5th injector was a staged injector but it was pulsed. its pulsewidth was incremental with the boost pressure and triggered with the crank position. all of this was done in the ECU for the car. your setup is going to be similiar, instead of running off the rail your getting a second pump, and a second gas tank and running a second fuel. all of which adds to the complexity, and thus reduces the reliability. i would highly recommend a failsafe even for the system your developping.
good luck though, and let us know how it works.
If you ran 93 and your 5th injector was e85 then it would be the similiar. Your example doesn't have much relevance unless you post TB temps due to the 5th injector.
I cant run e85 here. We dont have it. It is a 2 hour drive one way to fetch the e99. Otherwise I would just be running e85 through 4 injectors.
Old Jul 31, 2007 | 10:35 AM
DSMu4ia's Avatar
Two of these:
http://www.atpturbo.com/Merchant2/me...egory_Code=FUL
Take the plugged port off the back of your AFPR, and use it to feed these two injectors along with help from a Y-adapter.
Wire the injectors up via the AEM.
BOOM. Presto. Finished.
Note: This will only apply if you run the ethanol as a main fuel, as well as injecting it.
Old Jul 31, 2007 | 10:40 AM
2JZfan's Avatar
Originally Posted by 94AWDcoupe
I am aware of all the calculations. But they dont mean much to me. Practical on car experience is what I am after. The cooling abilities is only a small part of the equation. It may only take injecting an additional 100cc of ethanol to equal the cooling properties of methanol. Then there is more heat energy per unit for a given amount of ethanol. Then there is detonation resistance. Who fares better there? F1 converted from meth to eth with no reported power losses. Top tuners in the drag scene say eth and meth are very near the same potential with meth getting the win by a few percent not 13%. Then there is the article of the high altitude planes that ran well on eth and meth but not isopropl. Again no real reports of ethanol injection the way I plan to try it. If you know someone who has done it this way please post a link.
My bet is the accuracy of injecting with injectors and the reliability will lead to far more potential then that of meth setups.
Your question, however, was how does ethanol compare to methanol. Not how does using fuel injectors compare to a more rudimentary nozzle system. You do realize that any purpose-built race car running methanol or ethanol are both doing so using regular electronic fuel injectors, so in the end, the only thing worth discussing is the properties of the fuels, not the method of injection. Besides, how is your setup really any different from cars that run on E85 through the primary fuel injection system? In both cases you have electronic fuel injectors doing the metering and you have a mixture of gas and ethanol.
Old Jul 31, 2007 | 12:12 PM
KevinD's Avatar
TB temps due to the 5th injector can be calculated by hand. and i'll tell you they are very close to what the data aq will show (and yes we did record intake temps on our car). there is nothing revolutionary about this system. it is simply injecting ethanol instead of methanol. both of which cool the air and are burned as a fuel. you can use a on/off valve at very high pressures, or a pulsed injector at lower pressures. both systems will work. both of them offer benefits and reliability issues. i guess i am missing what you are trying to ask in this thread... if injectors will work? sure, depends how you operate it. does ethanol work like meth? yes it does.
Old Jul 31, 2007 | 01:49 PM
94AWDcoupe's Avatar
Richard stated his parts were not compatible with gasoline. Maybe he can chime in here. But regaurdless of that answer the sureflow pumps are not reliable on meth, changing to ethanol isn't going to change the reliability level.
My point to this is all alky kits on the market need a failsafe because they are no where near as reliable as your factory fuel system. You cant build second factory like system and inject meth. But you can inject ethanol this way.
Since no one I know has tried this I am going to give it a shot. The question I want answered that no one seems to be able to answer is if you inject ethanol at same quantities as meth (20% of total fuel) will it perform as well as methanol?
My question is not how methanol works as a primary fuel. My question is not how ethanol works as a primary fuel. My question is very specific in bold above. So far one has theorized it will work the same and one has theorized in will not be as affective. I dont know whats so confusing about all this. Yes you can run fuel pumps and injectors on methanol but THEY DONT last. Drag racers generally pickle the system after every race. (they run gas through the system to flush it out) So running a system like I am designing here to use with methanol is a complete rediculous nono. I would never have used water injection systems in the first place if you could reliably run meth through an injector.
Old Oct 12, 2007 | 09:39 AM
ride5000's Avatar
here is a bit of a comparison between the two:
http://forums.nasioc.com/forums/show...5#post19574425
in short, no, they are not absolutely equivalent, as meth has ~50% more oxygen by volume than ethanol does, and evaporates quicker. their latent heats by volume are pretty close though.
hth
ken
Old Aug 7, 2009 | 05:28 PM
LCEvo's Avatar
i switched as well
Old Nov 2, 2009 | 12:41 AM
klever's Avatar
me too
94AWDcoupe
44
Nov 6, 2017 08:40 AM
Cloud0307
Feb 10, 2017 12:45 PM
Richard L
149
Feb 27, 2016 03:01 PM
scheides
271
Jan 6, 2013 10:06 AM
4WS Tuning
116
Oct 21, 2011 03:08 AM
