Aquamist
the HFS-5 is progressive. The amount of meth/water it sprays will mirrors your injector duty cycle. This means that when the system first turns on only a very small amount will be injected and then as you use more fuel, more water/meth is injected. This is what progressive means.
The HFS-1 is not progressive; it is either full on or full off.
They both have the same failsafe technology, gauge readout, pump, etc...
The HFS-5 will be easier to tune and smoother in the delivery of meth.
The HFS-1 is mostly for people who want a very simple meth system but also want the added benefit of having a very high quality failsafe, and other kit components. In my opinion it makes more sense to get the HFS-5.
Or you can by the HFS-1 now and upgrade later for ~$275
Thanks Alex. A little technical correction though. The HFS-5 is not progressive its linear to the flow of fuel. The HFS-5 uses the HSV (High Speed Valve) and the FIA2 to mirror you FIDC so that W/A injection is more or less a mirror of the fuel injection system = load is more accurately addressed with this system.
the turn on point where the methanol starts coming in causes a large change in the amount of gasoline that needs to be injected. its like instantly adding 20% more fuel, thus your injectors must inject about 20% less when the meth turns on. because tuning a car is done using lookup tables, this causes a problem where the table doesn't have the ability to fine tune a transition where the meth turns on (they only have so many fields where you can tune in the tables). you wind up having a lean spot before the meth turns on, or a rich spot immediately after. it takes quite a bit of work to balance the transition point.
partial throttle sometimes trigger the injection, not an issue at all
I agree - I have found the HFS-1 to be really easy to tune and a total delight
While the HFS - 4 is slightly smoother and easier to map - in the end the HFS-1 is a really neat kit and a total pleasure to work with
Al
Al
when i set up my system back in jan2007, i went with a boost trigger = 10psig. I was not sure of how things will work out then using idc trigger. The few hfs i have done since have been idc triggered and i like it better.
