Meth leaking after short trips normal?
Old Aug 15, 2007 | 11:28 PM
SlowCar's Avatar
Originally Posted by TTP Engineering
Good to hear from your Spencer. Your car is the prime example I use when explaining why not to use the safeinjection system.
We have developed our own system specifically removing all the problem areas that other kits employ. Push on brass fittings, mcmaster nozzles, meth solenoids, paddle wheel sensors, and inappropriate pumps are all areas we have insured were NOT used in our kit for maximum reliability and 100% methanol safe.
when a kit is put together right, it WILL NOT leak. Such a kit will run water methanol in any concentration without any issues.
Old Aug 16, 2007 | 03:21 AM
PHDoc19's Avatar
I was under the impression that when an injector was not receiving a signal it was closed, meaning that it shouldn't be leaking, right? Methanol can be an oxidizer but it shouldn’t be any more corrosive than any of the crap that gas companies put in their mixtures. Also the placement of the reservoir should not really matter due to the adhesive properties of methanol. It's a lot like water when siphoned, once you get it going, it will continue to flow.
Old Aug 16, 2007 | 04:27 AM
Evoryder's Avatar
i tried the solenoid...it didn't work for my situation...i had it powered up correctly...didn't open on time, then eventually not at all...i got it in a drawer some where lol
Old Aug 16, 2007 | 05:11 AM
SlowCar's Avatar
Old Aug 16, 2007 | 05:13 AM
SlowCar's Avatar
Old Aug 16, 2007 | 06:44 AM
TTP Engineering's Avatar
Meth injection systems do not use electrical injectors.
Old Aug 16, 2007 | 07:43 AM
05evoGSR's Avatar
instead of a check valve what do you think about setting something up that when i turn the car off i hit a button or a switch to reverse the pump flow briefly to drain the line back to the tank and when i start the car the next time prime it to refill the system? not sure how complicated that would be but sounds like it would solve my problem.
Old Aug 16, 2007 | 08:14 AM
PHDoc19's Avatar
Oh, I apologize for the interjection, but thanks for the info.
Old Aug 16, 2007 | 08:17 AM
PHDoc19's Avatar
Originally Posted by SlowCar
I just like throwing a little chemistry in when I can. Chemistry is fun
Old Aug 16, 2007 | 08:28 AM
Shurflo pumps are one way pumps only.
Even if you could do that, it is a matter of gravity which will end with the same result.
Old Aug 16, 2007 | 08:40 AM
05evoGSR's Avatar
hhmm what do u suggest i do? I mean the car is my daily driver and i dont want this to kill my engine.
Old Aug 16, 2007 | 09:27 AM
SlowCar's Avatar
get rid of unnecessary parts, simplify the system
tank -> pump -> solenoid valve -> atomizing nozzle + relay/hobbs swtich + a good failsafe
Old Aug 16, 2007 | 09:31 AM
xiaoni420's Avatar
What he said.
Old Aug 16, 2007 | 09:35 AM
SlowCar's Avatar
Originally Posted by xiaoni420
What he said.
go to class
Old Aug 16, 2007 | 09:37 AM
xiaoni420's Avatar
Soon, what I should be doing is writing papers. Have you done my homework yet Abner??
