Adding a flow meter
Old Aug 24, 2007 | 01:55 PM
cpoevo's Avatar
Adding a flow meter
I have the Snow Stg 2 with Safe Injection. I know the SI goes off at <188ml/min. I want to try and integrate a flow meter that I can hook up to the Aux input on my ZT-2. Does anyone know where I can find one that might work? I looked at McMaster by the way and didnt see anything that looked compatible.
Abner please read this because I am betting you will have an answer.
Old Aug 24, 2007 | 02:07 PM
UCB's Avatar
UCB
What is the outpute of the flowmeter you already have. If its a 1-5V signal you should be able to use a multimeter to see what the voltage is at 188ml/min and set up the fault band accordingly on the ZT2
Old Aug 24, 2007 | 02:12 PM
SlowCar's Avatar
cp: i use the aquamist dds3 flow sensor voltage output fed to the zeitronix aux input.
Old Aug 27, 2007 | 03:31 AM
Richard L's Avatar
I think The snow system uses a flow switch, it does not give a progressive voltage with flow - just an on/off output.
You really need to get a proper flow sensor with a 0-5V output relative to fluid flow.
Marcus Lim
Sep 2, 2014 11:27 PM
MCPunk79
Jul 31, 2012 05:56 AM
chrisnicole88
Oct 26, 2011 02:05 PM
lemmonhead
19
Nov 24, 2008 10:54 AM
06redMR
46
Oct 31, 2006 06:53 PM
