<<<Tuned with meth>>>
Old Sep 4, 2007 | 08:06 PM
  #31
xiaoni420's Avatar
Originally Posted by SlowCar
speaking for yourself...so whens the stock ecu to aem ems swap for you?
It's in the works Abner, I'm trying to find the best deal!
Old Sep 4, 2007 | 08:08 PM
  #32
Evoryder's Avatar
Originally Posted by APEX1
Yo evoryder why not the hfs-1 or the 5?
why not? If it aint broke....
Old Sep 4, 2007 | 08:09 PM
  #33
SlowCar's Avatar
  #34
Evoryder's Avatar
Originally Posted by binh
why not? you unplug the factory ecu and plug the aem in
If you say so
Old Sep 4, 2007 | 08:11 PM
  #35
SlowCar's Avatar
you running an on/off injection system right?
Old Sep 4, 2007 | 08:14 PM
  #36
Evoryder's Avatar
If my evo had a smilie for when the meth kicks in, that would be it lol
3000rpm.....3500rpm (((((100% METH)))) "YIPPEEKAYAAAAY....
....6000rpm....7200rpm, *SHIFT!!!!!!* ...."FLAME ON"
Old Sep 4, 2007 | 08:17 PM
  #37
Evoryder's Avatar
Yes. Comes ON @ 14psi..
  #38
SlowCar's Avatar
good stuff
Old Sep 4, 2007 | 08:18 PM
  #39
xiaoni420's Avatar
Hahah, you are definitely an addict. I completely understand though
Old Sep 4, 2007 | 08:27 PM
  #40
beemerfreak's Avatar
Do u guys get meth from gas stations? Or tuner shops? How much does a meth kit go for with a fail safe?
Old Sep 4, 2007 | 08:34 PM
  #41
APEX1's Avatar
I get mine from a speed shop 10 mins from me. 5bucks a gallon
Old Sep 5, 2007 | 10:59 AM
  #42
BlueSi's Avatar
my tuner said he used the middle nozzle.
What injector size are you using?
Do you know if you are using 2 nozzles or just 1 nozzle for your HSF-1 kit?
I'm looking to run 100% meth for my car too, but all my calculations tell me I need more than (2) 1mm nozzles for my injectors. I probably calculated it wrongly
Old Sep 5, 2007 | 11:01 AM
  #43
nutrulz's Avatar
Tym Switzer is a crazy tuner, albeit good.
Old Sep 5, 2007 | 11:05 AM
  #44
SlowCar's Avatar
each of the 1.0mm atomizing nozzle flows as much as a stock injector. Using 2, you are flowing a LOT of methanol
Old Sep 5, 2007 | 03:24 PM
  #45
BlueSi's Avatar
My car's a rotary. Will be using (2) 1000cc and (2) 1600cc injectors. You think I'll need two 1mm nozzles?
