<<<Tuned with meth>>>
Old Sep 12, 2007 | 02:00 PM
  #61
binh's Avatar
Originally Posted by dudical26
Any way for you to upload a graph or just a log of your AFR from the dyno runs or even a run on the street. It would be nice to see what AFR they tuned for.
It would be really helpful, thanks.
I could do that for ya.
You're probably more interested in initial spool afrs but I know afr's towards redline are about 11.2
Old Sep 12, 2007 | 02:11 PM
  #62
dudical26's Avatar
11.2 seems very rich, I wonder why they did this. Abner's car for example appears to hit 12.5 during spool and hold 12.0 to redline.
Thanks for the info.
Old Sep 12, 2007 | 02:22 PM
  #63
binh's Avatar
I just wanted it to be conservative especially when the temperature swings when winter comes. I want that cushion
Old Sep 12, 2007 | 02:37 PM
  #64
Jeff_Jeske's Avatar
It would also be nice to know the exact nozzle that they used. AFR depends alot on how much meth you are actually injecting as fuel and how much is being used as a chemical intercooler.
Old Sep 12, 2007 | 02:42 PM
  #65
binh's Avatar
.9 and 1.0mm. The bigger one further away from the throttle body.
Old Sep 12, 2007 | 03:00 PM
  #66
APEX1's Avatar
Im doing 100% meth
1 nozzle .9
Now my tuner said that running 2 nozzles with 100% Meth ON MY CAR was WAY too much meth!
hope this helps some.
Old Sep 12, 2007 | 03:21 PM
  #67
APEX1's Avatar
now I have the HFS-1. I think if I had the HFS-5 it would be different.
Old Sep 12, 2007 | 04:01 PM
  #68
Evoryder's Avatar
12.0 A/f is pretty standard on 100% meth...11.2 is definitely conservative...
Old Sep 12, 2007 | 09:06 PM
  #69
APEX1's Avatar
I was told when it goes under 50 degrees to turn my boost down.
Old Sep 12, 2007 | 09:24 PM
  #70
Jeff_Jeske's Avatar
^^ That AFR is conservative but 30psi is not.
Old Sep 12, 2007 | 09:29 PM
  #71
binh's Avatar
I've lowered mine to 28 for daily driving
Old Sep 12, 2007 | 09:48 PM
  #72
APEX1's Avatar
im running 30 psi and I was told that my tune was really not pushin it.
really everyones evo knock thresh hold is not the same.
We will see in time if my tune is too aggressive.
Old Sep 12, 2007 | 10:21 PM
  #73
Jeff_Jeske's Avatar
That is just an amazing dyno chart man simply beautiful.
I'm curious what you are using to regulate the 30psi. I know you have a Forge MBC but is it maxed out?
Old Sep 12, 2007 | 10:23 PM
  #74
APEX1's Avatar
Thanks man!
actually no its not. lol
Old Sep 12, 2007 | 10:26 PM
  #75
APEX1's Avatar
Tym Switzer is a Buschur disciple.
Many people have recomended him over the competitor.
