AEM meth kit questions.
Old Sep 4, 2007 | 08:55 PM
APEX1's Avatar
Dude you have all those mods!! And your tryin to cheap your way on a alky kit. This is just foolish man!
Old Sep 4, 2007 | 08:58 PM
Pure Playaer's Avatar
also even with the AEM one it says that the pump is only made to handle 50% meth
APEX1's Avatar
I seen alot of people on here blowin up there motors on the SMC kit. you know why?
cause they run 100%mth and the smc pump can't handle it- the pump fails- theres no fails safe and bang motor gone.
Old Sep 4, 2007 | 08:59 PM
yeah but all those mods are what made me broke.
I have n ems, headstuds, motormounts, ignition, and soon methkit that need installing n tuning, so to save almost 200 bucks on a meth kits pretty good to me..
also i havent gotten any suggestions on any other meths kits yet
APEX1's Avatar
I would say before you buy- do like week or 2 of more research on alky please cause I almost made the mistake your thinking about!
good luck playa
what about the fail safe where you wire the SMC kit into the aem ems?
Old Sep 4, 2007 | 09:01 PM
I would say before you buy- do like week or 2 of more research in alky.
good luck playa
thanks man, ive done some research but to be honest the majority of it is opinionated.
i want to run n m15 nozzle, probably with the m3 type of meth..
Also can anyone tell me thed ifference between m1 and m3 meth? besides m3 being more expensive
Old Sep 4, 2007 | 09:04 PM
APEX1's Avatar
Bro there is a lot of threads on your questions. like I said do 1-2 more weeks of research!
Old Sep 4, 2007 | 09:07 PM
SlowCar's Avatar
VP M3 methanol is bad for the pump......
https://www.evolutionm.net/forums/sh...d.php?t=290128
Old Sep 4, 2007 | 09:10 PM
Boltz.'s Avatar
FCOTM Winner
^ Ditto. Looks like you have 7k in mods without labor and you worrying about saving $200 on a meth kit? It just doesn't make any sense...
Old Sep 4, 2007 | 09:13 PM
ok so i just read up on alot of your stuff including your thread in your signature about the aquamist + dds3 failsafe.. man if you could come here n set up my meth kit that would be great haha.
is there anyway to run additional failsafes with the aem ems like i keep asking. ive read somewhere, actually quite often, that the smc can be wired into the ems
Old Sep 4, 2007 | 09:20 PM
evovin's Avatar
aem meth kit's pump is 150 psi smc pump max 100psi only....this is the only big thing im aware of those two kits that you've mentioned.
Old Sep 4, 2007 | 09:23 PM
SlowCar's Avatar
35psi max...not 100
http://www.flojet.com/files/rlf_series_f100-196.pdf
Old Sep 4, 2007 | 09:27 PM
so let me try and understand.. smc uses flojet pump and it will only run 35psi? and aem's meth kit will run 150psi?
i think i might just get the AEM meth kit.. but what would be the downfall of using 100% meth on a pump that according to this website says can only handle 50%?
Old Sep 4, 2007 | 09:33 PM
APEX1's Avatar
AB,
this guy sounds like me a month ago.
School um
