meth/oct.
Old Oct 15, 2007 | 06:39 PM
APEX1's Avatar
meth/oct.
How many points of octane does the meth give our pump gas?
Old Oct 15, 2007 | 06:52 PM
mrMTB's Avatar
According to this site, a 5% mixture of methanol will raise the octane of the pump gas by 1-1.5%.
http://www.procarcare.com/icarumba/r...dia_fuels1.asp
Old Oct 15, 2007 | 06:53 PM
SlowCar's Avatar
depends on how much you inject
more meth = more octane and more latent heat of vaporization...
Old Oct 15, 2007 | 06:54 PM
mrMTB's Avatar
So here's another link...
http://www.gnttype.org/techarea/misc/octanebooster.html
FORMULA 4
Methanol or Ethanol
R+M/2...101
Cost...$0.60 - $1.75/gal
Mixtures with 92 Octane Premium
10%...94.3 Octane (Methanol)
10%...94.7 Octane (Ethanol)
20%...Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combines with water.
SlowCar's Avatar
on the aquamist HFS-1 or the HFS-5, you can calculate it since the injection is predictable...
Old Oct 18, 2007 | 07:05 AM
dlabonte's Avatar
A 50/50 mix of water/methanol, when injected in the right qty, will raise your base fuel octane by 25%.
Best regards,
Dan
Old Oct 18, 2007 | 07:20 AM
deadbeatrec's Avatar
im injecting 100% meth with the aquamist HFS-1 using the .8mm nozzel. anyone know what my octane is?
Old Oct 18, 2007 | 08:06 AM
Mad_SB's Avatar
No because we do not know what size injectors you have
Old Oct 18, 2007 | 08:45 AM
SlowCar's Avatar
the delivery of methanol by the HFS-1 is very constant and virtually rippleless/pulseless - knowing your injector size and duty, you can easily calculate it. the published octane number of meth i've seen is ~110-115...also there is the latent heat of vaporization part which contributes to the anti-knock property.
