noticing a failure trend for SMC pumps.
Old Nov 5, 2007 | 07:49 PM
EvoTech's Avatar
For the 3rd time my SMC pump has failed. 2 out of the 3 times the car was sitting for a couple of months. After sitting for a while the pump refuses to turn. I guess the seals dry out and just fall apart or something. Just a little heads up to test the pump if the car sits for a period of time. Steve has been very good about replacing broken parts, but after 3 pumps and 2 controllers, I can say that this is getting very old. Glad that I am running a failsafe even if it is a crude one.
Old Nov 5, 2007 | 07:54 PM
staatz's Avatar
Get a Coolingmist Pump and wire it into your SMC controller. I have an SMC controller, with 2 gallon tank and coolingmist Pump. ***** FLY=D
Old Nov 5, 2007 | 08:03 PM
EvoTech's Avatar
Thanks for the tip. I was not sure if that would work with the funky ground trigger wiring that smc uses.
Old Nov 5, 2007 | 08:07 PM
SlowCar's Avatar
a shurflo draws more current than a flojet...will the controller handle it?
Old Nov 5, 2007 | 08:10 PM
scheides's Avatar
EvoM Moderator
Can you elaborate on the timeframe for all of this? i.e. ran fine for 10 months, parked car for 3 months, ran for 1 week, failed pump, ran for 4 months, sat for 2 months, ran for 1 day, failed, .....etc?
I've had mine now since January, no sign if deterioration...
Old Nov 5, 2007 | 08:39 PM
TwStDeVo's Avatar
im scared of this as im sure numerous people on this forum are as well. luckily, i have the aem and it only goes to my alky map if it sees power from the pump, but i want something that i dont have to worry about ever failing. interested in the coolinmist pump idea, any more info?
Old Nov 6, 2007 | 04:43 AM
EvoTech's Avatar
I think that I have more problems than most becasue I run a seperate map for the meth. I have it on a switch and do not use it all the time which may give the seals time to dry out. Two of the failures happened after the car was sitting for over 6 weeks. All of the failures happened within about 2 years of owning the smc kit.
Old Nov 6, 2007 | 07:08 AM
TwStDeVo's Avatar
i have a switch as well (turbo xs manual boost controller) with my aem.
GTVEVO
AEM EMS
74
Jul 5, 2011 10:46 AM
cij911
Nov 16, 2010 12:38 PM
AF-Evo8
12
Jun 27, 2008 06:44 AM
Lasersleeper
21
Aug 18, 2007 06:23 AM
Derek888
Aug 12, 2006 08:34 AM
