anyone using a hand pump to fill methanol tank?
Old Dec 14, 2007 | 03:35 AM
EVO8LTW's Avatar
I'm wondering what the easiest way is to transfer methanol from a 5-gallon drum to the tank in the trunk. Is anyone using a hand pump of any sort? If so, what kind? I just want an easy, no spill way to handle methanol.
Thanks.
Old Dec 14, 2007 | 03:40 AM
Evoryder's Avatar
i just transfer from the VP drum to a 5 gal gas can. You can just get a funnel with custom tubing. that should be easy enough.
Old Dec 14, 2007 | 05:22 AM
SlowCar's Avatar
Old Dec 14, 2007 | 10:54 AM
Mad_SB's Avatar
Thanks.
I use a crappy hand siphon pump from pep boys for the moment. The location of my bottle makes it tough to get any kind of funnel or even funnel / tube combo in there
Old Dec 14, 2007 | 10:55 AM
Mad_SB's Avatar
Dam SlowCar, where did you find that one? looks like the **** compared to the 1/4" tube that is on mine.....
Old Dec 14, 2007 | 11:02 AM
Rez90's Avatar
http://www.vpracingfuels.com/handpump.html
Old Dec 14, 2007 | 11:04 AM
SlowSportSedan's Avatar
i just a funnel with an extended hose. works well
Old Dec 14, 2007 | 11:09 AM
SiCKlEyWiKeD's Avatar
I put my meth in a windshield washer fluid bottle. I just use a funnel to pour from the 5g pale to the bottle. It's clear so it actually looks like windshield washer fluid
Old Dec 14, 2007 | 11:10 AM
and then to get to my tank I use the same extended funnel with the flex hose
Old Dec 14, 2007 | 11:26 AM
SlowCar's Avatar
i got it when i went back to tucson az...from ace hardware. $3
Old Dec 14, 2007 | 06:34 PM
Ultimate CC's Avatar
I had a couple feet of hose hooked up to the 13gallon drum of meth I kept at the shop...
Old Dec 14, 2007 | 06:52 PM
2MucHP's Avatar
Yea that's what i use along with my mouth. I do the same when i need gasoline.
Old Dec 17, 2007 | 11:28 AM
Mad_SB's Avatar
Originally Posted by Rez90
This one works well for 55gal drums, that what we use at the shop. But I keep a 5gallon can of 50/50 at home for fill ups, need to get one of abners 3$ ace hardware siphon pumps.
Old Dec 17, 2007 | 11:53 AM
SlowCar's Avatar
here is a link to the hand pump
http://www.hardwareandtools.com/invt/u865386?ref=gbase
Old Dec 18, 2007 | 05:48 AM
Mad_SB's Avatar
Originally Posted by SlowCar
You rock man thanks for the link!
EvoLutionized8
12
Aug 10, 2016 02:59 PM
mt057
Jan 30, 2010 11:14 PM
EVO8LTW
Feb 20, 2008 05:56 PM
SlowCar
Nov 29, 2007 06:48 PM
