Cheap source for methanol tanks
Old Dec 15, 2007 | 05:17 AM
EVO8LTW's Avatar
Originally Posted by aqmist
Theres an SRT-4 user that had an Aquamist HFS-5 with one of those tanks. The float light on his DDS3 was triggered with a half a tank and the bargraph display got wacky during some hard street pulls. He switched to a taller less squat tank and the issues went away. Based on the failsafe being used a user may or may not know theres an issue by using this type of tank.
If the Flambaeu tanks are not liked try a 1 gal fuel cell, at least with with these theres room (because of the wide filler opening) to allow for fuel cell foam to be installed. Price for this solution is typically under $80.00
I have a 1 gallon cell that I'm going to install and it came with foam, but I assumed that the foam wouldn't be methanol compatible. You've got one of those cells in your SRT-4, right -- do you use foam? If so, what kind?
Old Dec 15, 2007 | 06:20 AM
aqmist's Avatar
I used to use a Summit Jr Dragster 1 gallon fuel cell. It was in my opinion a perfect supply tank since it was not a fuel enrichment tank = did not have extra fittings (AN bulkhead) for fuel delivery and return. It had one ball check valve feed type fitting and one external vent with a large fuel filler opening. The fuel cell makers have extra hardware for extended and angled filler necks as well as remote filler mounting, and tank mounting straps so basically the tank even though designed for jr dragsters had the same qualities of a traditional fuel cell. I mounted my tank to a go cart engine mounting plate and hung it and the pump setup from my rear strut bar. I now have two 6 qt Flambeau tanks and a custom mounting setup that both tanks and the pump are mounted to.
Old Dec 15, 2007 | 06:22 AM
EVO8LTW's Avatar
I used to use a Summit Jr Dragster 1 gallon fuel cell. It was in my opinion a perfect supply tank since it was not a fuel enrichment tank = did not have extra fittings (AN bulkhead) for fuel delivery and return. It had one ball check valve feed type fitting and one external vent with a large fuel filler opening. The fuel cell makers have extra hardware for extended and angled filler necks as well as remote filler mounting, and tank mounting straps so basically the tank even though designed for jr dragsters had the same qualities of a traditional fuel cell. I mounted my tank to a lawn mower mounting plate and hung it from my rear strut bar. I now have two 6 qt Flambeau tanks and a custom mounting setup that both tanks and the pump are mounted to.
Did you use foam in the cell? I have the same one. BTW, does yours say JAZ on the side?
Old Dec 15, 2007 | 06:24 AM
aqmist's Avatar
Also wanted to add that most fuel enrichment tanks that typically get mounted in the trunk for nitrous setups are more taller then squat and this is done so as to minimize fuel slosh.......same is true for W/A supply since the same laws of physics apply
Old Dec 15, 2007 | 06:26 AM
aqmist's Avatar
Yes I did use the foam but at the time my setup was 70/30 water methanol. I did not check into if the foam had issues with methanol.....................hmmmm I need to double check that.
Summit part, looks the same as the other name brands.
Old Dec 15, 2007 | 06:28 AM
aqmist's Avatar
price went up
http://store.summitracing.com/partde...5&autoview=sku
"They include B-83054 Mil Spec safety foam"
Old Dec 15, 2007 | 08:58 AM
EVO8LTW's Avatar
I ordered the Summit part too, but I got a Jaz cell. Looks just like that but says JAZ on the side.
Old Dec 15, 2007 | 09:26 AM
VIPGarage's Avatar
Originally Posted by SlowCar
those tanks are not ideal for injection...base is too wide
you want tall and slender bottles, minimise sloshing and uptake of bubbles into system
He is absolutely correct. I wouldn't run that tank for Meth either.
Old Dec 15, 2007 | 09:32 AM
SlowCar's Avatar
these flambeau tanks are cheap and robust
Old Dec 15, 2007 | 09:48 AM
JordanS4's Avatar
I thought Nick was crazy with 2 tanks. That there just puts my 1/2 gallon tank to shame
Old Dec 15, 2007 | 09:51 AM
SlowCar's Avatar
there is plans to build a system with more tanks
Old Dec 15, 2007 | 09:55 AM
JordanS4's Avatar
hahaha that doesn't even make sense ^^^^^ are you really that lazy to just refill it every once in a while? think about all the unnecessary excess weight.
Old Dec 15, 2007 | 09:56 AM
EVO8LTW's Avatar
I think at a certain point too large of a supply of methanol in something other than a fuel cell would raise eyebrows at tech inspection, particularly at a road racing event.
Old Dec 15, 2007 | 10:00 AM
SlowCar's Avatar
this is a fun picture richard@aquamist made
Old Dec 15, 2007 | 10:01 AM
SlowCar's Avatar
just wondering...will those be an issue of they are fill with water instead of meth?
