Snow Performance Boost Solenoid Problem..
Old Jan 13, 2008 | 11:04 AM
BOOSTEZ's Avatar
All:
I've had my Meth kit for about 4 months now. I never really drove the car hard (racing it) until a month ago. I've noticed that when I hit it hard and switch gears, that the boost only goes to 15psi for a second or so inbetween shifts until I get full boost (25psi). I've troubleshot it down to the fact that the boost control solenoid (from the Safe Injection Kit) must not be working properly and opening the solenoid inbetween shifts, allowing the wastegate to open, then closes and I get all my boost again. I've disabled the solenoid (breaking ground) for now until I figure out if the Safe Injection Kit was installed properly.
Any suggestions on how it should've been hooked up? I'm not even sure if I have the upgraded solenoid that allows flow to stop instantly (even though my tank was installed in the trunk). I went to the webpage but there are no instructions on installing the Safe Injection Kit. The original Meth kit appears to be working but I doubt the Safe Injection was installed properly. Also, when the boost solenoid bleeds back boost, the orange light doesn't illuminate (which it should).
-M
Old Jan 13, 2008 | 11:07 AM
Ultimate CC's Avatar
when does your kit turn on boost wise... what safeinjection do you have the si05 or the si10?
Old Jan 13, 2008 | 11:12 AM
BOOSTEZ's Avatar
The kit starts to spray when boost is at 11psi. I'm not sure which Safe Injection kit I have. The module which accepts the flow line is near my battery, what should I look for?
If I punch it in one gear and let out, it's fine. Acceleration is smooth and there is no knock.
-M
Old Jan 13, 2008 | 01:29 PM
Do you know what nozzle you are running...is it a 375ml/min
Old Jan 13, 2008 | 06:23 PM
BOOSTEZ's Avatar
Not sure what nozzle. I know it's not the larger sizes that came with the kit. My tuner told me that those were too much for my stock turbo.
-M
Old Jan 13, 2008 | 06:31 PM
Well what I am thinking is that you have a 375 nozzle and a si10 unit and the nozzle isn't flowing enough to keep the si10 from triggering...it could be other things though...
Old Jan 13, 2008 | 09:14 PM
C6C6CH3vo's Avatar
Sensor is seeing no flow for a split second while pump is getting first voltage, the SI sol is energized. Your only option, if sensitivity is already backed up, would be to widen your start and full margin's or find a solenoid withgreater resistance coil (3 port)
Old Jan 14, 2008 | 10:53 AM
BOOSTEZ's Avatar
That's what I figured. Is there such a solenoid from Snow? How come noone else is seeing this?
Old Jan 14, 2008 | 10:58 AM
BOOSTEZ's Avatar
If that was the case, I'd see the problem on full throttle in any gear without switching gears. It would've been noticed on the dyno right away.
Old Jan 18, 2008 | 11:36 AM
SnowTech's Avatar
You can try turning the actiavation delay all the way up. Adjust the delay potentiometer fully counter-clockwise.
Old Jan 22, 2008 | 07:10 PM
Labonte MotorSports's Avatar
SnowTech - when did you buy an Evo? I thought you both drove jettas?
legacydestroyer
Sep 13, 2015 06:17 PM
scheides
271
Jan 6, 2013 10:06 AM
Thore
Mar 18, 2012 10:06 PM
4WS Tuning
116
Oct 21, 2011 03:08 AM
lapulapu
Sep 9, 2008 05:52 PM
