Rear washer spraying when meth is on
Old Mar 5, 2008 | 07:02 PM
BCOZEVO's Avatar
Just as the title says when I am boosting and the meth kit kicks in my rear windshield starts spraying based on how much boost I am at.
Is pump pressure to much creating a back pressure and forcing meth out of the closest exit point (rear washer)?
Old Mar 5, 2008 | 09:06 PM
Pr3z's Avatar
Your joking right?
Old Mar 5, 2008 | 09:19 PM
BCOZEVO's Avatar
nope dead serious, it looks like the car is taking a **** on the back window
Old Mar 5, 2008 | 11:37 PM
RazorLab's Avatar
haha best post on Evom I have seen in awhile...
Old Mar 5, 2008 | 11:50 PM
boozeup&riot's Avatar
+1
to the OP - sorry man, I wish I could help. Thanks for sharing anyway, and good luck. If I had to guess I'd say someone the injection kit was hooked up to the same switch/actuator your rear window sprayer was on and some lines got crossed somewhere... But thats just my uneducated guess.
Old Mar 5, 2008 | 11:56 PM
RazorLab's Avatar
Or he is using the windshield res bottle and kept the rear windshield lines on? :-X
Old Mar 6, 2008 | 02:04 AM
BCOZEVO's Avatar
Old Mar 6, 2008 | 02:13 AM
purevibez's Avatar
wow. i can see what razor said though.
Old Mar 6, 2008 | 08:47 PM
rhinotech's Avatar
rofffffl..
did you figure this out man?
Old Mar 8, 2008 | 01:11 PM
Ultimate CC's Avatar
HUH? can you show me how you have this wired as well
Old Mar 8, 2008 | 07:39 PM
BCOZEVO's Avatar
Wiring on the Snow pump is not touching anything on the reservoir other then putting the meth line into the reservoir everything is still stock.
And its not like the washer starts spraying full blast, it just drips out then as boost builds more and more, fluid sprays out more and more...
I am thinking of un hooking the rear washer water line to see if it comes out the front this time.
Old Mar 10, 2008 | 05:09 PM
John F's Avatar
Sounds like your washer pump is getting a feed from the meth pump. The more voltage your meth pump gets the more voltage your washer pump is getting. It sound like there is something wrong with the wiring or meth pump earth.
Old Mar 11, 2008 | 02:31 AM
Richard L's Avatar
I have been thinking about this for sometime. John F's explanation is more likely, check the grounding wire between the two pumps.
Mirage2.0
11
Mar 16, 2008 06:50 PM
Pure Playaer
Jan 3, 2008 09:17 PM
steelcityevo8
AEM EMS
19
Dec 26, 2007 10:14 AM
Seitz
14
Jun 26, 2006 03:06 PM
