How to wire in Tru-Boost to HFS-1 please
Old May 7, 2008 | 03:03 PM
paintballproam's Avatar
Can some one tell me how i wire the Tru-Boost into the HFS-1 meth kit?
Old May 7, 2008 | 03:05 PM
Richard L's Avatar
can you email me the user manual?
Old May 7, 2008 | 07:06 PM
Nevermind
i was told to wire into the ground for the tru boost
Old May 8, 2008 | 07:03 AM
KevinD's Avatar
yeah, you can cut power or ground to the true boost, or you can clip one of the wires going to the boost control solenoid. the best way to do it is by cutting a wire to the boost control solenoid, that way it doesn't turn the gauge off completely every time it goes into a failsafe.
if there are only two wires going to the boost control solenoid, either one of them can be cut, and the yellow and orange wires can be spliced into it.
alternatively (and this is more of a catch all for EBCs), you can cut the ground wire to the guage and splice in the yellow and orange wires. this will turn the gauge off, and thus the boost control completely when a failsafe happens. its better to do it this way if your EBC has more then two wires going to the boost control solenoid, and your not sure which does what.
Old May 8, 2008 | 01:03 PM
Well i wired it in to the ground wire. And i took it for a test ride. I did see the gauge display flow when i was under boost, but when i shifted, the tru-boost errored out and i had to reset it. Whats wrong?
Old May 8, 2008 | 01:18 PM
when i first set it all up, i had it idling, and i pushed the test button and it displayed flow, i let go of the button, and tru boost showed error
Old May 8, 2008 | 01:36 PM
the ground wire actually goes to the solenoid, thats what i tapped into
Old May 8, 2008 | 04:17 PM
what it is, is, whenever the pump stops flowing, it kills the boost solenoid, then when the pump flows again, it gives power to the solenoid which is fine for any other EBC, BUT the Tru-boost is tied to the gauge, and it needs to be reset everytime it finds an error IE the ground wire being "cut". So how do i find away around this?
Old May 8, 2008 | 04:31 PM
Richard L's Avatar
Can you send me a link to the Tru-boost manual.
I will read it through and shed some light.
Old May 8, 2008 | 06:04 PM
Hey its actually working now under boost
now time to tune
whotippedmycow
Jun 19, 2013 06:03 PM
STIKiller4G63
Nov 7, 2012 11:05 AM
nismo n9ne
Mar 12, 2012 03:59 PM
paintballproam
16
May 15, 2009 07:37 AM
RansomRacing
12
Aug 25, 2007 09:37 PM
