AEM tru-boost any one use it?
Old Sep 20, 2010 | 06:40 PM
nismo n9ne's Avatar
dose anyone run the aem tru-boost? if so how do you like it? an anyone else feel free to chime in with any thoughts.
Old Sep 20, 2010 | 06:42 PM
liam11's Avatar
Ya , nothing really to complain about with it. Does everything its suppose to lol..
Old Sep 20, 2010 | 06:50 PM
EvosnatcH's Avatar
my 2 cents.. i use a 3 port boost controller just like this one http://evodynamics.com/3portpn.html which is ecu controlled. the temptation of having the ability to change my boost without hooking up my laptop is too much for me! but if you want to go with the aem i have not really heard anything bad about them, and your getting a boost gauge and boost controller all in one.
Old Sep 20, 2010 | 06:58 PM
n2oiroc's Avatar
*wink*
https://www.evolutionm.net/forums/sa...tru-boost.html
Old Sep 20, 2010 | 07:02 PM
SLO-EVO's Avatar
it was a PITA to set, and my selenoid went really fast on it. i got rid of mine asap. i will stick to the manual controller.
Old Sep 20, 2010 | 07:35 PM
MetalSpoolDoom's Avatar
Its a nice unit but I've found that 3 Port is the way to go. Look into if your looking for Boost Control system.
Old Sep 20, 2010 | 08:02 PM
diablo1's Avatar
I have it on my car, is so easy to use.
Old Sep 21, 2010 | 07:17 AM
EAVWIDL's Avatar
Nice gauge, I had no problems installing and setting up. The one problem I have had was factory setting didn't read high enough boost. We contacted AEM and got an upgrade to read more boost. After install things went great. Within 4 months though boost started reading incorrectly. Sometimes as much as 8 pds difference. Still haven't been able to remedy problem. With all that said if your not pushing over 30 lbs of boost I think this gauge is well worth the money. If you plan on ever pushing more boost you may want to look at manual controller.
Old Sep 21, 2010 | 06:21 PM
MikSchultzy's Avatar
I had to configure it, took me probably two hours. Issue with it that I had was the documentation was pisspoor on how to set it up - but the install was easy.
I also want to say it causes boost taper, but don't all evo's taper boost? (I'm tapering about 4psi)
Otherwise, great gauge. I love the warning and the bar that progresses. I put it into my ash tray, just like this: https://www.evolutionm.net/forums/ev...ost-gauge.html as it was a "Set it and Forget" gauge. I also like that I can close the tray off and most people wont notice it. Also helps when I get pulled over to not have all kinds of gauges everywhere when the cop leans in. And I am anti-clutter. But enough defending it - I understand that it's not terribly visible in that location either.
Old Sep 21, 2010 | 07:47 PM
sleeezy's Avatar
I have and I like it alot... it just took a bit of time to set it up and get it dialed in
Old Sep 21, 2010 | 07:53 PM
boostedwrx's Avatar
Takes 5 minutes to set up once installed if you know your wastegate crack pressure, doesn't have any more or less taper than any other boost controller that goes of WGDC and has a bleeder. Even with a 30psi spike you'll always taper to ~24-25psi on the stock turbo anyway. Other boost controllers that have the target boost feature are even more fun/difficult to setup and get working so I'd say the Truboost is one of the easiest I've used. I can't imagine using your laptop every time you want to change your boost either, thats silly to me. Ambient air temperatures changes are going to effect your boost so it's nice to be able to just reach down and lower the wgdc come winter time.
Old Mar 12, 2012 | 06:27 AM
DSMolition's Avatar
Old thread I know but what do people run the WG spring crack pressure at? I’m sure I’m not the only one using one of these things. Can’t seem to get over 26-27 psi with it maxed out.
Old Mar 12, 2012 | 03:59 PM
2003evo8's Avatar
i have it installed its a nice part but didnt like the boost options so installed 3 port but keep gauge in because its looks so pretty. lol and use gauge but not boost controller part
whotippedmycow
Jun 19, 2013 06:03 PM
fingjosh
Nov 18, 2011 04:03 PM
krackerstache
Cobb AccessPORT
Nov 4, 2011 08:46 PM
alpha812
Oct 10, 2011 02:46 PM
34Turbo
Nov 24, 2006 05:32 PM
