will it harm engine to turn off meth?
Old May 25, 2008 | 05:57 PM
snafufx's Avatar
I'm currently tuned to 25 psi (VERY conservative) on meth at around 11.3 A/F. I have an on/off switch in case my wife drives the car or I run out of meth. Now the question- will turning off the meth kit mess up my a/f ratio or cause any damage to my engine? Before the install, I was running 25 psi. I haven't bothered turning it off since it's so addicting, but I guess this is a "what if" type question. I'm now debating on getting two tunes, one for pump, and the other for meth, but with the psi so low, will it make a huge difference? Thanks in advance.
Old May 25, 2008 | 06:06 PM
VtexGt3's Avatar
i would not turn that off... unless you stay off the boost then it should be okay, but the meth is keeping the engine from blowing. Turn it off and drive without boost and you're fine, but if you hit boost you might run into some problems.
Old May 25, 2008 | 06:14 PM
kanyonkid's Avatar
u should get two tunes.... thats what im doing when i go meth...
Old May 25, 2008 | 06:43 PM
Evoryder's Avatar
might want to invest in a harness and have the 2 map switching feature courtesy of Tephra & JackofTrades... i have 2 maps myself.
Old May 26, 2008 | 03:19 AM
snafufx's Avatar
Thanks again for the advice, it look slike I'm going to have to get two tunes. The system is set up not to turn on until 10psi, so figured if I never hit 10+psi I would be fine.
Old May 26, 2008 | 08:17 AM
Evoryder's Avatar
which is true...now if your wife steps on it and you're out of meth. Kaboom...or if you were tuned by Al then he tunes it safe enough to not blow on level he set it to if the meth fails.
Old Jun 11, 2008 | 02:44 PM
fromWRXtoEVO's Avatar
The easy fix would be to turn down the boost whenever your wife drives it. Other than that you should have a secondary map, one for meth and one for pump and no meth.
Carlos
Old Jun 15, 2008 | 01:58 PM
Guz Man's Avatar
but wait... wouldnt turning off the meth, or running out of meth, would intiate the failsafe feature, and that would cause the car the run out of wastegate pressure (assuming that a mac valve is installed)..
i mean i paid the price of doing that.. (not having two map), and i ran on the same map with/without methanol, and that caused me to do a full block build
Old Jun 15, 2008 | 02:30 PM
snafufx's Avatar
On mine, no. Turning off the meth will run the same psi, just no meth. If the failsafe engages, then it's wastegate pressure. Basically what I wanted is if I ran out of meth, instead of running wastegate pressure, just turn the system off and run at 25 psi. Before the tune, I was running 25 psi, and after tune still at 25 psi, so figured if I turned it off, it wouldn't have much effect. I got mine very conservative which is what I got.
Old Jun 15, 2008 | 07:36 PM
codean's Avatar
The answer is still no.
Your fuel map and timing maps are surely different from what you had when you were tuned without alcohol injection.
Old Jun 15, 2008 | 08:36 PM
tweaker41's Avatar
To do it safely you would need to ensure that while the meth is off you ensure there is not WOT driving and you stay out of boost! Like stated above your fuel map and timing map will still be configured for the car running on meth and if the meth kit is turned off your failsafes will not activate. Get two maps for the ECU!
Old Jun 16, 2008 | 04:04 PM
Levar's Avatar
Veteran: Army
Carlos
I agree with you fellahs. But to answer your concerns, why are you cheating your wife? If she wants to get crunk while driving, let her. Nah, seriously, having two maps available would pay the best dividends for you and for your wife as well. Get in the car, hit the switch, and you're all set. It'll be a terrible thing to get caught on a long road trip with no methanol available.
