Life span of alky pump?
Old Aug 18, 2008 | 01:47 PM
johnjonfenomeno's Avatar
Ok I have had my meth kit for over 2.5 years now. It's an smc trunk mount kit and I can tell it still works because when I prime it, I see the afr's drop.. but I dont see the yellow light saying it's spraying until like .5 seconds after.. I know this light is pressure triggered meaning it will light up once the pump builds a certain pressure. Reason Im concerned is I use this signal to control my ebcs and switch maps on my aem. So is the problem the pump?
Old Aug 19, 2008 | 08:41 AM
Devilsown's Avatar
Most all pumps being used the amount of time they are used "only under boost" should outlast the car. I have pumps here that are 3 years old that have been ran 24-7 30mins on 15mins off. Smc does use a differnt pump design but you should get similar lifespan.
Old Aug 25, 2008 | 08:41 AM
cfdfireman1's Avatar
On a trunk mount you have to charge a lot of line before pressure is built up.
Old Aug 25, 2008 | 12:23 PM
Yah but my interior cabin after sitting a while has a strong smell of alky.. Seals may be going?
Old Sep 18, 2008 | 03:40 PM
Evoryder's Avatar
https://www.evolutionm.net/forums/sh...eth+pump+years
My pump after a 3 years...100% meth all the way
Old Sep 18, 2008 | 09:51 PM
shaman's Avatar
Are you running a check valve or solenoid? IF you smell alky then something is releasing it into the cabin
Old Sep 18, 2008 | 09:55 PM
Its a trunk mount kit... I tested it and the problem is coming from the seals. I contacted Steve at SMC and I sent it in he replaced the seals.. problem solved
