air fuel ratio with 50/50 water/methanol
so, what do you guys recommend af ratio for evo8 with green turbo, tbe, IC, 50/50 methanol/water injection(aquamist hfs5)?
i am at 11.1-11.3 from spool up to red line.
is it safe to lean out more? like to 11.5-11.7's?? with methanol/water injection?
iirc, if you are still using the 2 jets that was installed when the system was 1st installed...you will be able to tune in the 12s...
proceed with caution.
Here's an image of the color rings on the jets the color indicates sizes
Here's the chart with the color to size
Take a quick peak underhood at the installed jets and cross reference to the chart.
Here's a correlation of the jet versus flow using the Aquamist/Shuflow pump
Nice to see people who were in on the GB's still enjoying the kits
I am currently at 11.1 pretty much throughout RPM range at WOT....I am going to try to lean a tad to get closer to 11.5 (and see how the car responds)...I am curious if anyone has logged HP increase from 11.0 to 11.5 -- I'd be surprised if it is more than a few HP at most, but that is a pure guess...
