Aquamist compression fittings
Old Nov 21, 2009 | 10:45 AM
mt057's Avatar
Aquamist compression fittings are awesome. I recently got a few to cure a meth leak I have from a connector on my pump (system is over a year and half old). The fittings are easy to use and went on like butter. From my reading it seems like meth leaks are random problem for everyone. I feel that this will solve it for the most part. Now if there was a bullet proof pump too...
Thank you Richard at Aquamist and Jeff at Howerton Engineering
Old Nov 28, 2009 | 08:43 AM
mt057's Avatar
Here are some pics of compression fittings I have on the way from Howerton Engineering. I let my system run dry and did boost leak testing. I have found that my old fittings before my medium speed valve are causing a boost leak. I believe that when the pump was not running that the boost pressure was causing weeping of the quick connectors as well. I am changing out all the old quick connect fittings to the compression fittings to stop the boost/meth leaks.
Sorry won't let me post same pic twice. Once they arrive I will post new pics and everything assembled.
https://www.evolutionm.net/forums/wa...rt-thread.html
seven10
Jun 4, 2016 05:16 PM
kjcs9
Jan 28, 2016 08:37 PM
fred 62
15
Nov 15, 2007 04:56 AM
eve-slow
May 29, 2007 06:22 AM
Richard L
22
Apr 24, 2007 01:53 PM
