HFS5 failsafe not reverting to actuator boost
Hi all, I have an issue with my HFS5 setup using the mach valve for the failsafe. The problem is the boost I will not revert to the wastegate 15-16 psi when the aquamist is off. First test was to connect the wastegate directly to the compressor vacuum outlet to confirm my wastegate boost pressure which i manged to get the 16psi. 2nd test was to connect the hallman pro boost controller alone and unscrew it completely. This gave me 20 psi
. When I implement the mac valve, the boost stays at 20psi even when the aquamist is off. Shouldnt it bypass the boost controller and revert to the 16 psi? Any help would b greatly appreciated
Sorry.
Can you tell me the following:
1. What version of DDS3
2. Post a wiring diagram
3, Is the hallman boost controller a manual or electronic type?
I believe the connection to the I/O ports may have been incorrect. I
scheides
124
Feb 6, 2014 02:15 PM
EvilTechnology
Feb 28, 2013 05:29 AM
Brent kuz
Sep 8, 2010 08:28 PM
afmafia
Aug 8, 2008 04:55 AM
Evoryder
22
Nov 6, 2007 09:19 PM
