has anyone modded there intake mani for meth injection?
Old Sep 5, 2010 | 01:11 PM
evo9ben's Avatar
Just a question i tried searching... has anyone tapped into there intake mani and have installed 4 injectors to spay water/meth 100percent in all cylinders... anyone have pics... lmk thanks
Old Sep 5, 2010 | 06:56 PM
impact blue's Avatar
I hear thats the new fad now but if its done wrong like tapped wrong or anything it will leak badly and get al dirty and ****.
Old Sep 5, 2010 | 06:58 PM
Wickedwhite8's Avatar
I'm interested in this theory.
Old Sep 5, 2010 | 07:18 PM
420a-t's Avatar
I havn't done it but if I were to run meth again this would be the only way I would run it. It's the same idea as a direct port nitrous kit. drill/tap 4 holes on the bottom or top of the mani runners and hook it up!
Old Sep 5, 2010 | 07:19 PM
420a-t's Avatar
Kinda like buying anything or installing anything incorrectly...just like making sure you dont weld a t3 flange for an evo-style turbo. Its not a big deal to make sure you have the right size thread and its welded correctly.
Old Sep 5, 2010 | 10:16 PM
esevo's Avatar
I have done it. Aquamist can provide the necessary components to go that route. ($150 +/-) I would only use a Aquamist HFS-6 with DP due to the amount of control it provides.
Also consider a very strong ignition will be needed due to large amount of liquid pooling up on the valves. Stock rods could be subject to bending or breaking under a misfire condition or where high volume of liquid compression is present.
Also know this is complete overkill for 50/50 WM or 100% meth. 2x's jets in the IC will do more than enough and distribution is more than equal with any amount of methanol 50% or more. With more h20 the harder the distribution becomes due to higher viscosity. This is solely based on climate, WMI kit choosen, install ect, ect.
Evan Smith
Old Sep 5, 2010 | 10:44 PM
evo9ben's Avatar
that looks awsome man just what i was thinking of doing if i go back to meth because of all the issues on not getting meth to all the cylinders and them cracking or whatever and warping
Old Sep 5, 2010 | 11:10 PM
420a-t's Avatar
I lik this distribution block from devils own for direct port:
http://www.alcohol-injection.com/dir...grade-205.html
Old Sep 6, 2010 | 08:35 AM
JHowerton@Aquamist's Avatar
There are some components to make it easier if using Aquamist parts. 4-port distribution manifolds as seen in the picture and aluminum weld bungs for for the intake.
Attached Thumbnails has anyone modded there intake mani for meth injection?-direct-port-1.jpg
Old Dec 20, 2010 | 05:19 PM
Stage2evo8's Avatar
i bought my car with it tapped there and suppsoedly worked well but i wold upon buying the car
hktrigguy
Oct 31, 2016 07:50 AM
BrownSuga
May 20, 2016 01:36 PM
evogottago
11
Jan 11, 2009 06:58 PM
playafly
29
Jul 18, 2008 09:08 AM
1mbrews8
Nov 17, 2007 02:54 PM
