quamist hfs1 install problems
Old Oct 28, 2010 | 09:17 AM
jos's Avatar
jos
i read the install manuals and the info on the site, but i have come across the problem i am having. i install the kit according to the diagram attached but when i turn my key to ignition the jets is spraying the water continuously before the car even starts up and even after i turn ignition key off. it continues to spray for about 5 secs. what is my problem i down loaded the injector trigger diagram for my ecu which is a evo 7. is like the the trigger is is on direct power from the battery even though i make ajustment to the trigger is spraying with out stop until i take the key out.
Old Oct 28, 2010 | 11:25 AM
mt057's Avatar
I hope that you currently have the jets unhooked from the uicp. That said if you could take a pic that would help diagnose it. For the HFS-1 to pump like that the trigger has to be grounded. Double check all of you wiring. What version are you using?
Old Oct 28, 2010 | 03:13 PM
jos's Avatar
jos
the jets are not in the piping good thing we tested it outside pluming. i will try to take a pic, what exactly do u want to see
Old Oct 28, 2010 | 03:16 PM
mt057's Avatar
The board wiring and settings. Glad to hear that it was unhooked.
Old Oct 28, 2010 | 03:17 PM
jos's Avatar
jos
i disconnected the green trigger wire thats hook up to injection pluse signal on the EMS and the pump is still spraying when i turn the ignition to the second click
Old Oct 28, 2010 | 03:28 PM
jos's Avatar
jos
Aquamist install problem
I sending pics now
[ATTACH]quamist hfs1 install problems-dds3-computer-1.jpg[/ATTACH]quamist hfs1 install problems-dds3-computer.jpg
Click image for larger version
Name:	DDS3 COMPUTER 1.jpg
Old Oct 28, 2010 | 03:45 PM
jos's Avatar
jos
Please i need help lol the pics are of the wiring i have to the dds3, as i stated the pump is coming on at the second ignition click along with the jet and spraying before i can start the car, i disconnected the trigger wire which is the green one in the pic above and the jet still spraying water crazy.
Old Oct 28, 2010 | 04:00 PM
mt057's Avatar
Do you have an mbc?
Old Oct 28, 2010 | 04:08 PM
mt057's Avatar
At second look the trip adjust is turned all the way to the left. Try turning the trip adjust clockwise a so it is pointing to the 12 o' clock postion.
You also appear to be missing two wires that connect to the pump relay + and - . The wires go to the msv.
Old Oct 28, 2010 | 08:51 PM
jos's Avatar
jos
Yes i have a mbc
Old Oct 28, 2010 | 10:41 PM
jos's Avatar
jos
i turn the trip clockwise to 12 oclock and further still same results. the 2 wires coming from the aquamist relay into the computer box are red and blue and i connected them to the blue- and red+ on the dds box is this what you mean? what is the MSV
Old Oct 29, 2010 | 12:22 AM
mt057's Avatar
There are two wires for each pump relay as shown in the diagram. I was refering to medium speed valve and the red and blue wire that come from it (I believe its called msv). It should have to wires coming off of it. I will try and bring this to Richard L. attention and see if he has any idea. www.waterinjectioninfo.com has tons of info as well.
Old Oct 29, 2010 | 04:04 PM
jos's Avatar
jos
i found out why the pump was spraying all the time, the harness was wrong the flow sensor harness was hook up to flow level in the meth tank harness i switch them around the gauge now lights up when i turn ignition t o clicks, but now i am not getting the jet to spray i blizt the throttle after start up but the bump now not running or jet spraying. is this now a trigger source problem or did i burn out the dd3 or pump relay?
Old Oct 30, 2010 | 03:31 AM
Richard L's Avatar
Jos,
When you purchase you the system, did you get the original harness? If you did not purchase the system new.
First of all, check the folllowing:
1. The DDS3's pin 23 only receives 12V power at the "pre-crank" position.
2. The default trigger is set to "PWM". Check the jumper link.
3. Disconnect the trigger wire from the fuel injector, ground it, tell me with the system sprays. (simulating 100% fuel DC)
Richard
mto57 - thanks for notifying me at the waterinjection.info forum. I am still out of the office until 5th November. My internet access is limited.
Old Oct 30, 2010 | 10:08 AM
mt057's Avatar
After you do what Richard suggested and verify that the system works on forced trigger. I would readjust the trigger threshold to where you want it (what I suggested to turn to 12 o'clock). This will have to be done while the car is driving. It should not kick just by giving the throttle a blip. I would not trigger mine unless sitting on my two step for to long while staging at the drag strip.
If it will not trigger like Richard said then post up another pic of your board.
Ps. You can also leave the trigger wire in place and then take an extra piece of wire and touch one end to the screw for the trigger terminal and then ground out the other end of the wire. This will cause it to force to work if it does (as Richard said)
