Evo 9 Aquamist HFS-6 Alt Map
I have installed my HFS-6 and am currently trying to figure out how to wire it for alt map as a Failsafe. The manual does tell you which wire, pink one, but does not say where in the Evo 9 ECU you wire that up to. Any help would be appreciated.
Thanks
Thanks
I have just added Tephra altmap for evo 8, 9 and X for HFS-6 on the following link*:
(*may need to register first)
http://www.aquamist.co.uk/vbulletin/...ead.php?t=2008
https://www.evolutionm.net/forums/at...attachment.pdf
Yes, you need to add a pin. I had bought a map switch kit from Buschur a while back for my old meth kit and then wound up going with the Aquamist kit. Since the map switching is built in to this kit I just needed the pin from the map switch assembly.
Yes on a IX you have to add a pin and do some easy electronics to have less than 5V on the input when running on Alt map. If you do not feel confident with wiring and/or ROM tuning, go with someone who knows about both.
Cheers,
C>
Cheers,
C>
blacktab420
Feb 2, 2016 09:51 AM
EvoPower81
11
Jun 2, 2014 08:07 PM
ChuckP
Feb 4, 2010 07:04 PM
