Meth/Water
Simply adding methanol to the current setup should make a little power without tuning ( it has a higher octane rating). If it causes you to run pig rich because you are jetting a decent amount without a tune and wash out your oil... That is a different story.
It is best to get a tune to maximize power gains while keeping the car running at desired afr/timing.
You can drive around with the system off while you are on your way to get a tune.
What WMI system are you running? What size and how many jets did you choose? Do you have an afr gauge?
High octane does not make more power this is a misconception, higher octane ratings just allow you to tune more aggressively because they are less prone to knock. If the tune was on the ragged edge where knock was induced, allowing the timing to drop then it could be beneficial. Simply adding more of any fuel will reduce power on an already properly running vehicle. Even the lower AIT's the water/meth injection will allow wi be outweighed by the richening of the fuel mixture.
I miss spoke saying octane rating when I was meaning to refer to oxygen content.
Methanol has higher C - H ratio compared to other fuels. Thats why it burns stoich with greater quantity of fuel respectively. Relative octane just happens to be high due to physical characteristics. In fact lower octane fuels tend to make more HP. Nitro has octane of like nothing.
The reason methanol burns more powerful ly is because it burns so damn fast from ignition to CO2, even when slightly over or under rich, and when timed precisely you can target more of the combustion near the sweet spot.
Add water and power is lost. Ethanol is like its weaker sister
No. I went two years of with 1-2.5 gph progressively spraying in a 660cc motor. Did I lose power, sometimes yes. Was I required to tune for it? I guess no explosions, metal shavings, sounds, or anything else proves that it won't spontaneously combust when extra fuel is injected.
