espelir
Old Oct 24, 2005 | 08:32 PM
lukytry's Avatar
espelir
I know some one here has one, my question is. Does the exhaust come straight out in the rear, or does it sit at some what of an angle?
Old Oct 25, 2005 | 10:24 AM
housedj's Avatar
it is at an angle.
Old Oct 25, 2005 | 10:26 AM
1sweetoz's Avatar
How good does it sound? Is it full 3"?
Old Oct 25, 2005 | 10:29 AM
housedj's Avatar
Mine is a full 3.17" (80mm) actually. when my exhaust was tested (catless) the idle was @ 103db & 110db @ 3k RPM. it has a small resonator so there is nothing holding the noise back. i threw the silencer away.
Old Oct 25, 2005 | 05:41 PM
lukytry's Avatar
Originally Posted by housedj
it is at an angle.
can you post some pics??
plz?
Old Jan 30, 2006 | 08:24 PM
Hunt27162's Avatar
What does it taper to at the cat?
Old Jan 31, 2006 | 07:37 AM
housedj's Avatar
it doesn't taper at all. i will try to get pics for you guys this week.
Old Jan 31, 2006 | 02:41 PM
Karash's Avatar
Hm, my JGT500 tapered at the cat slightly on my 2003. Did you have custom work to re-flange it?
Old Jan 31, 2006 | 06:47 PM
lukytry's Avatar
Well i finally got the Espiler and I love it. I do also think it tapers at the cat orelse it wont bolt up. What i want to know is if anyone has the Espelier DP and what do you think. When i got the catback the DP where on back order.
Any one with the espelir cat back, what Dp are you using and are you using a straight pipe aswell.... feedback pleeeeease...
Old Feb 1, 2006 | 01:17 PM
Karash's Avatar
I used a HKS DP with a works resonated test pipe. Everyone that heard my car said it sounded mean as ****
Old Feb 1, 2006 | 01:23 PM
ddubb's Avatar
I have an espilir DP and UR high flow cat, I am installing it this weekend but I hear it clears the ACD fine if you have an 05 evo. I helped my friend put his espilir DP/UR high flow cat on his 03 evo and had no clearance issues and he love the set up. I think my friends exhaust sound even deeper growl than just my cat back if that is any indication of the difference.
Old Feb 2, 2006 | 12:31 PM
housedj's Avatar
sorry mine does taper a pinch. i run a Perrin DP with a Perrin test pipe & CEL box.
Old Feb 2, 2006 | 12:40 PM
Vroompsh's Avatar
i run the Espelir catback with a Helix DP, and now a UR hi flow cat (formerly a UR test pipe). Sounds great, and everything bolts up perfectly, no clearance issues.
jcdeng
11
Sep 15, 2014 09:29 AM
Buschur_TSI
Aug 19, 2012 10:12 PM
burtomr
22
Sep 3, 2010 08:00 PM
DSMEVOLUTION
Midwest Region
10
Jan 23, 2007 09:10 PM
OZLancerlunatic
Mar 17, 2004 09:41 AM
