San Diego Evo's
Old Apr 10, 2008 | 09:13 AM
  #3481
alan678's Avatar
Originally Posted by evo racing
does anybody know how to tune an SAFCII? do i still need a wideband to tune it?
SAFC tuning is the Evos most primitive form of tuning in existence...and its the worst by far as well, the only way that you are going to see significant gains are with tuning fuel AND timing, not just fuel as done with the SAFC...
Food for thought....the stock Evo flash has about 8 counts of knock on 91 oct, just imagine what the knock counts are going to be when you lean out the fuel mixture to the desired 11.2 AFR for peak output (stock is about a 10.0 anything after 5k rpms where is also where the most knock is seen on a stock flash)....
So, with that said....don't wast your money on that SAFC and get flashed.....You got PM...
Old Apr 10, 2008 | 11:06 AM
  #3482
CharlieGsanD's Avatar
+1 for getting a tune before using the SAFC
the main problem with SAFC controllers is the way they go about making changes to the fueling by modifying the MAP/MAF signal.
on modern cars the MAP/MAF signal is used not only for fueling, but also controlling ignition timing.
so if you want to remove fuel, you essentially "trick" the ECU into thinking the engine is not working as hard & thus you use less fuel, but here is where the problem lies. if you are tricking the ecu into thinking the engine is not working as hard, it will also add ignition timing & like alan said, the OEM tune already has aggressive timing & if you cant add timing, you cant remove fuel :/
one way of using the SAFC is to have your ECU reflashed but use mild ignition timing to give you some working room so you can add/remove fuel with the SAFC before you start getting into knock
Old Apr 10, 2008 | 01:08 PM
  #3483
SEvoIX's Avatar
Checkin in
Old Apr 10, 2008 | 05:01 PM
  #3484
1QYK9's Avatar
I may be buying some PTE1000cc injectors within the next month or two. Would anybody be interested in buying some PTE880cc injectors around that time?
Old Apr 11, 2008 | 10:16 PM
  #3485
uSmC_08's Avatar
I'll take them Justin.
Calling dibs right now
Old Apr 11, 2008 | 10:17 PM
  #3486
uSmC_08's Avatar
Shoot me PM on price btw
Old Apr 12, 2008 | 06:56 AM
  #3487
1QYK9's Avatar
Sounds good. Like I said before though, it is going to be a month or two before I'll purchase the PTE 1000ccs, so I can't sell you my 880ccs until then. If you are willing to wait that long then it is all good.
Old Apr 12, 2008 | 12:31 PM
  #3488
brokenRS's Avatar
this thread is getting slow. lets do a tech day, bbq or somesort of meet in sd
Old Apr 12, 2008 | 12:54 PM
  #3489
uSmC_08's Avatar
That's fine...Shoot me PM when you're ready and I'll take em!
And yes, we're due for a BBQ/dyno day
Old Apr 12, 2008 | 01:30 PM
  #3490
im always down for a tech day
Old Apr 12, 2008 | 01:48 PM
  #3491
1QYK9's Avatar
Cool! Shoot me a PM and let me know what you'd pay for them. Keep in mind that they retail for $372.
Old Apr 14, 2008 | 06:21 PM
  #3492
alan678's Avatar
Ummm....herro!
Old Apr 14, 2008 | 07:32 PM
  #3493
alan678's Avatar
Old Apr 14, 2008 | 07:47 PM
  #3494
alan678's Avatar
Old Apr 14, 2008 | 07:51 PM
  #3495
nigletsyz's Avatar
I've got three OEM oil filters for sale. $4/each or all three for $10.
I know you guys change your oil. Hit me up. I'm in Clairemont but travel up to San Marcos Mon-Thurs
