San Diego Evo's
Its going to be about 2+ weeks...
My alternator is not charging under a load which can cause issues within the tune as injectors are affected with the change in the voltage...
And I have a crack on a weld on my exhaust manifold....first confirmed case on the manifold according to ETS, but they have 100% warranty on the work....
Also need to find an IAC thats worth a dam....I think my current one is blown out...
All in all the car is drivable but just not ready for a date with the rollers...
Really looking forward to seeing what your Evo makes with the new setup.
Got this done yesterday
Changed my Timing Belt, Balance Shaft belt, all the pulleys/tensioners, front engine seal, cams seals and Installed my new Cosworth M2 cams with Brain Crower Valve Springs & Retainers....
And I also got my SE wheels back on the car with some 255/40 Falken RT615 tires
Your Evo is simply sick. I gotta give Andrea's Evo some serious love to compete with you!
Andrea and I have an appointment next Tuesday with Reese Tuning to have the following parts installed and tuned:
AEM EMS w/5 BAR MAP sensor and IAT sensor
RRE MAP sensor adapter plate
Invidia 02 housing
PTE 1000cc injectors
The tune will be on good old 91 octane. A few weeks after this install we'll bring the Evo back for tuning on E-85.
Invidia 02 housing
http://www.socalevo.net/index.php?op...&topic=57605.0
http://www.socalevo.net/index.php?op...&topic=57641.0
I have some T cases for sale. Here is a link to the thread. Ready for pick up.
James Reese
James Reese
I know you guys probably wont care....BUT....I tuned my first Subaru today on teh Dyno
It was a 2002 WRX with basic bolt ons (TBE, Intake, FP, 650cc inj, FMIC) and an Evo 3 16g....
On pump gas @ a low 18-17lbs (cause subies dont <3 teh boost like the Evo does) it made 291 awhp and 268ft lbs.....not to shabby for something that makes barely 200 awhp in its stock form...
Also, on one pass that the boost was a tad to high (23lbs) it made 300ft lbs but I aborted the run due to the high boost...
Just thought I would share
