San Diego Evo's
Old Aug 22, 2008 | 10:48 AM
  #3991
1QYK9's Avatar
Originally Posted by alan678
Not on pump gas...lol!
Why not? With the power I am making I should be running 7.1-7.2s at the Q.
Old Aug 22, 2008 | 10:57 AM
  #3992
alan678's Avatar
Originally Posted by 4cefed
Jesus Alan every time i see your signature your numbers get higher!!!
Lol....@ 456whp I started to encounter ignition issues with the OEM ignition....my pulls were only good to about 6k rpms...I got back on the dyno after addressing the issue by lowering the gap on the plugs down to .016 (temp band aid fix) and I am able to rev to 8k with no problem now....
Lets see I haven't been to the Q in a while, my driving skills might be a little rusty....
My last successful session at qualcomm netted me a 7.431 @ 94.73 mph with the FP Green on MS 109 making 452whp and 442 ft lbs....
I am just going out tonight to regain the best 91 oct numbers at the Q from someone's 7.887 @ 90mph
Old Aug 22, 2008 | 11:01 AM
  #3993
1QYK9's Avatar
If you don't beat that time then you need to be flogged. We need to change the categories:
Stock appearing turbo on pump gas
Stock appearing turbo on alternative fuel
Non-stock appearing on pump gas
Non-stock appearing on alternative fuel
That's pretty much how BR did the DSM shoot-out.
Old Aug 22, 2008 | 11:07 AM
  #3994
alan678's Avatar
Here is my FP Green on MS 109 vs my 35R on 91 oct Dyno Chart....
The FP Green was in 3rd gear and the 35R was in 4th gear (We standardized 4th gear pulls after I had tuned my car on the dyno with the FP Green...) which explains why the FP Green pull is smoother looking than the 35R pull...
The reason I am posting this chart is so that you can see how hard it will be to beat my old FP Green MS 109 times @ the Q....
I will change the categories once the need for it comes....I dont want to be the onlt one in the "Non-stock appearing on pump gas" class
Old Aug 22, 2008 | 12:13 PM
  #3995
1QYK9's Avatar
You gotta remember the fact that once you hit second gear you should be at full boost for the remainder of the run through each gear if you shift quick enough (and I am not talking about not lifting either). With that said, you should be able to take advantage of your horsepower/torque gains.
Old Aug 22, 2008 | 12:28 PM
  #3996
1QYK9's Avatar
I ran 7.8s with the following power:
With some better driving I should have ran 7.6-7.7s. Now that the power looks like this:
I shouldn't have any problem running 7.1-7.2s at the Q with good driving. I am making 12-13psi at launch now. Of course this is all talk. Need to back it up at the track!
Old Aug 22, 2008 | 01:01 PM
  #3997
1QYK9's Avatar
Alain can take the 91 octane record...I am going for the alternative fuel record. Move over Alain! LOL!
Old Aug 22, 2008 | 01:04 PM
  #3998
alan678's Avatar
Lol! GET SOME!
Old Aug 22, 2008 | 01:09 PM
  #3999
1QYK9's Avatar
Lol! GET SOME!
Just gotta get that Exedy installed and then it is game ON! Of course you'll then get tuned on race gas and take back the record...until we get an FP Red!
Old Aug 22, 2008 | 01:13 PM
  #4000
alan678's Avatar
It will be never ending man
In the spirit of competition.
Old Aug 22, 2008 | 01:19 PM
  #4001
1QYK9's Avatar
Its will be never ending man
May the quickest car win! Or is it may the better driver win?
Old Aug 22, 2008 | 02:28 PM
  #4002
4cefed's Avatar
holy choppy dyno sure you wanna run the 476 map?
Old Aug 22, 2008 | 02:48 PM
  #4003
alan678's Avatar
4th gear pulls on the dyno read like that due to the amount of data it collects per rev vs to a 3rd gear pull....the smoothing of 2 doesn't help either....
Old Aug 22, 2008 | 03:29 PM
  #4004
4cefed's Avatar
true true, I'll see you guys at the track tonight too bad I'm still waiting on my clutch from Tilton
Old Aug 23, 2008 | 12:40 AM
  #4005
alan678's Avatar
Nice seeing you out there man!
Best pass of the night was a 7.505 @ 93.36 MPH with a 1.779 60 ft....this was done on straight 76 Brand 91 oct...
