Need help changing brake pads
Old Jul 30, 2003 | 06:28 PM
KTRLancer02's Avatar
OK kareem if you listen to the bleeding the breaks bit im gonna kill you, you dont need to do that, as a matter of fact, i have never done that.
If you need help come over my house. We will help you, the right way, my dads a mechanic. Joes right.
Old Jul 30, 2003 | 07:40 PM
Iamkar33m's Avatar
Hey Karlen, turns out imma go with ur dad's dealy (u know what im talking about). Ill ttyl about it =)
Old Jul 30, 2003 | 07:52 PM
MSanad's Avatar
Listen bro, People Learn from their mistakes, So just go at it urself, like someone said before, If u F#$% up then u'll learn, If not then you learned the cheap way, and there's no better feeling than knowing u did that $#!T by urself, Like dam, I DID THAT ALL BYMYSELF! know what i mean...?
Old Jul 30, 2003 | 07:56 PM
rhitme03's Avatar
NAPA has pads for Mitsu... 14 and 17 mm wrench, wood block and C-Clamp... Definately don't need to bleed if you have a manual (shares with clutch) - not sure about Autos though.
Took me 23 minutes to do both sides.
Old Jul 31, 2003 | 10:27 AM
Iamkar33m's Avatar
Well, MSanad... If you realize that the brakes are needed to stop the car, you wouldnt wanna f*** up on them otherwise u might learn how to be dead from ur mistake. It's best that you have someone teach u the first time and then the next couple times u do it yourself. Thanks for the heads up on NAPA rhitme03.
Old Jul 31, 2003 | 05:05 PM
rhitme03's Avatar
NAPA pads seem slightly better than stock... way better than stock pads 65% worn with crud in them.
PMPN8EZ
Mar 27, 2016 08:15 AM
okyu5632
Evo X How Tos / Installations
Sep 3, 2014 03:59 PM
Hmoneybagz
37
Aug 28, 2014 08:46 PM
Thahomeboyb
Jun 10, 2014 06:56 AM
kaonashi
10
Jan 3, 2008 07:52 PM
