need a tune in az
Old Jul 12, 2008 | 04:25 PM
justa4banger's Avatar
need a tune in az
i need a good tune on my car...like bad... the more mods i do the slower it feels....any recomendations???
Old Jul 12, 2008 | 04:26 PM
ROGERV's Avatar
Mynes performance in Mesa.
http://www.mynesengineering.com/
Talk to Mike, he will take care of you.
Old Jul 12, 2008 | 04:35 PM
how much hp should i b putting down
Old Jul 12, 2008 | 04:45 PM
ROGERV's Avatar
On their dyno I would say around 285whp Add some cams and you should be around 300whp.
I made 302whp and 297wtq on 20psi with similar mods and with cams.
(on their Mustang Dyno)
Old Jul 12, 2008 | 04:47 PM
so thats bout 300 on a dynojet right???
Old Jul 12, 2008 | 04:48 PM
ROGERV's Avatar
Correct.
Old Jul 12, 2008 | 04:49 PM
Mike@Mynes's Avatar
Hi Roger how've you been? hope all is well. Come by when u have time and i'll hook you up on the hood dampers
Old Jul 12, 2008 | 04:53 PM
ROGERV's Avatar
All is good.....I was eyeing them, will have to stop by next week to pick some up.
Old Jul 12, 2008 | 04:55 PM
Mike@Mynes's Avatar
it's kinda hard to say exactly what your car will make b/c every car reacts differently to mods. We will tune your car to a safe AFR in this heat... no telling how much your car will make but you will definately feel the difference before and after the tune. We charge $500 OTD for a Custom Tune (dyno time and tuner time included), but your map will be locked once it leaves our shop... just make sure you're comfortable with that before making your final decision.
There's a couple of things going against you right now:
- the AZ summer heat
- the crappy summer blend of 91 octane.
One recommened mod: Walbro Fuel Pump
cheers.
Mike @ mynes
by the way how much hp does a evo 9 put down wit turbo back and boost controller at stock boost
Old Jul 12, 2008 | 05:00 PM
Mike@Mynes's Avatar
at 19psi with TBE, MBC & fuel pump, about 290whp or so... some will log 300 in cooler weathers. At 300whp on our dyno, customers usually hit mid to high 12's depending your 60'.
350whp evo 9's on our MD have gone 11.8's and 11.9's in the 1/4 mile
Old Jul 12, 2008 | 05:09 PM
chaotichoax's Avatar
this is a review section...utilize your regional forum section
Old Jul 12, 2008 | 05:18 PM
SASD209's Avatar
Admin Alumni
Done
Old Jul 12, 2008 | 10:50 PM
Murf's Avatar
dynocomp in Scottsdale they use a dynodynamics dyno...
Old Jul 16, 2008 | 03:33 PM
fromWRXtoEVO's Avatar
If you are in Tucson then IAperformance. If you are in Phoenix then:
Mynesperformance
Vividracing
Dynocomp
UMStunning
last but not least arizonadynojet
I personally got tuned by 3 out of the 5 places I mentioned. If you still need anyone else to tune your car other than those shops I can also recomend other tuners around the area. The best deals as far is price is undoubtly IAperformance folwoed by arizona dynojet-dynochip(I think).
Carlos
