Las Vegas Evo's
Old Jul 22, 2005 | 01:51 AM
  #23536
gonzo's Avatar
Engine Tuner's Calculator.
http://wahiduddin.net/calc/calc_hp_dp.htm
Old Jul 22, 2005 | 01:52 AM
  #23537
gonzo's Avatar
Originally Posted by lil'evil_evo
gonzo do you have cams?
For almost two months now.
Old Jul 22, 2005 | 01:53 AM
  #23538
gonzo's Avatar
Originally Posted by LostSoul Evo
why are u guys tryin to get vp109? ya not even tuned for it. i read a post somewhere that changing ur boost on a tune might not be as beneficial as most think.
I wanted to get 109 because I was at half tank and half of 109 would get me 100 oct which is what I am tuned for.
Old Jul 22, 2005 | 01:54 AM
  #23539
gonzo's Avatar
Originally Posted by joEvo8
Thanks for letting me use those tools.. next time I'll be prepared.. HA!.. But Corey has it.
I saved you. That 12.8 run was because of meeeeeeeeeeeeeeeeee!
Old Jul 22, 2005 | 03:22 PM
  #23540
evilevovegas's Avatar
Hope the tracks open. *****es going down i hope (*****es being my slow *** times)
Old Jul 22, 2005 | 04:19 PM
  #23541
ronsevo's Avatar
how late you all be at pilot? i might meet u all at the track.
Old Jul 22, 2005 | 04:21 PM
  #23542
lil'evil_evo's Avatar
wow it's been awhile. what set up do you have?
Old Jul 23, 2005 | 12:41 AM
  #23543
joEvo8's Avatar
Damn.. its about 12:40 am and I'm at work.. guess what.. you guys know about that Thunder storm that came throught he night before.. well ... it hit the base pretty hard.. cause all our F-16s had Rocks and Pebbles in the Engine.. we had to inspect 20 of them.. Full borescope inspections.. .. this was not fun.. I could see the Drag strip from the distance.. but i had to get my mind off it to finish my job... and two jets collided into each other cause the wind was that strong.. sorry I wasnt out there.. I'll be going to Tuning Tech in the morning so I wont be goin to the track tonight at all.. tell me some good stories though..
Old Jul 23, 2005 | 12:43 AM
  #23544
joEvo8's Avatar
i can't disclose my findings on how many jets are bad.. .. just incase you guys were wondering..
Old Jul 23, 2005 | 12:44 AM
  #23545
dizzigital's Avatar
There's this little guy named VEGASBOI. And he likes to play with his little TOY.
THE END.
Old Jul 23, 2005 | 02:15 AM
  #23546
gonzo's Avatar
Not surprising. I'll find out Monday.
Old Jul 23, 2005 | 02:19 AM
  #23547
gonzo's Avatar
Check it.
My best time tonight...
13.091 @ 104.20
Best 60 foot was 1.811
Best trap speed was 105.68
So I improved my time by about 8 tenths and speed went up 10 mph. Too bad is was real humid tonight. Can't wait until fall. Times should drop dramatically.
By the way, we raped the subies tonight. My first run sealed their fate. I ran 13.1, fastest of the EVOs first runs. Their fastest all night was an STI running 13.6.
Old Jul 23, 2005 | 02:27 AM
  #23548
gonzo's Avatar
Calculated the Density Altitude. We were running at like 4500 feet above sea level. Using the altitude correction factor can give you a good idea of what you would run in ideal conditions.
So for instance, take the correction factor, which in this case is .9445 and multiply that number by your ET and you get a corrected time. Basically what the car would run at sea level.
.9445 * 13.091 = 12.36 ET corrected.
http://www.gnttype.org/techarea/misc/altitude.html
Old Jul 23, 2005 | 02:29 AM
  #23549
vegasboy301's Avatar
my best run was 13.6
Old Jul 23, 2005 | 02:31 AM
  #23550
gonzo's Avatar
Hopefully my calculations are correct. If not f uck it.
http://www.nhra.com/tech_specs/altitude.html
