Las Vegas Evo's
Old Sep 5, 2006 | 03:34 PM
  #34996
psiJunky's Avatar
Originally Posted by WhatNoise???
If the wheel says 5x114, I believe it means 5x114.3. Offset's sort of tricky to explain. Offset is the distance from the centerline of the wheel to the mounting surface of the wheel or where the wheel touches the hub. Centerline is zero (0). So … if you have a wheel with a +15 offset, the mounting surface is shifted 15mm outward (or toward the curb) from the centerline of the wheel. So the lower the number, the more aggressive the wheel will look with a bigger lip. You can actually have a negative offset too … like -20 for a supa-gangsta deep-dish. Even Pizza Hut® would be jealous. A +48 is going to push the mounting surface even further away from center, which is going to tuck more wheel underneath the car. I hope this all makes sense. I don't think that's going to clear. You could use a 10mm spacer, but I don't know how you feel about that. Chances are, that wheel with a +48 offset has a minimal lip and looks more like a fwd application…
Thanks Lee, I just talked to our parts manager and he explained the same way. The +48 is the honda/acura offset (makes since because there sitting on the dearlership showroom ) so I need to find them in a lower offset or use the spacers like you said, but I think that would hurt the performance aspect. That's what I get for thinking
Old Sep 5, 2006 | 03:37 PM
  #34997
WhatNoise???'s Avatar
Thinking is fine … when it's done in the right mind.
Old Sep 5, 2006 | 03:39 PM
  #34998
psiJunky's Avatar
They make them in a 17x8 +35 so that should not have any fitment issues using stock tires?
Old Sep 5, 2006 | 03:40 PM
  #34999
psiJunky's Avatar
I've never had a right mind (except to kick someone's a$$ )
Old Sep 5, 2006 | 03:42 PM
  #35000
I've seriously always been a fan of Kinesis wheels. They make some mess that looks pretty damn tuffy. Maybe I'm just a ricer …
Old Sep 5, 2006 | 03:51 PM
  #35001
702RSevo's Avatar
lmfao
BEatBOx FTMFW
Old Sep 5, 2006 | 04:06 PM
  #35002
Old Sep 5, 2006 | 04:12 PM
  #35003
20psiMR's Avatar
Photoshopped hotness!
Old Sep 5, 2006 | 04:16 PM
  #35004
R3dline's Avatar
so sik
Old Sep 5, 2006 | 04:34 PM
  #35005
rally-on's Avatar
i see a blue evo playing hide n seek in the back what up wit tat
Old Sep 5, 2006 | 04:36 PM
  #35006
rally-on's Avatar
anything going on tonight
Old Sep 5, 2006 | 04:44 PM
  #35007
R3dline's Avatar
theres a meet (FILV) behind in & out starts@ 8pm
Old Sep 5, 2006 | 04:50 PM
  #35008
You're ordering dubs!!!!
Old Sep 5, 2006 | 04:54 PM
  #35009
20psiMR's Avatar
Not my pic, someone else's used for photoshop. I think those are a PERFECT match. Hopefully they look just like that in person, Id be very very happy with those.
PS: Learning SQL today. Built a database from scratch. My fuggin head HURTS dude.
Update CDS_sql
set sqlsucks = yes, killingme = yes
where killingme = null
delete from CDS_chrisbrain
where braincells = 0
Old Sep 5, 2006 | 05:00 PM
  #35010
rally-on's Avatar
thanks see ya ther
