Las Vegas Evo's
Old Jun 3, 2009 | 12:02 AM
  #50236
monkeyevo's Avatar
hey guys i have question ? do i need the larger injector if i running 272 cossie cams ?
because i moved to san diego and i need to retuned my car because sea level then i call Reese tuning he told that i have to put bigger injector (680)that can add more fuel and boost up to 24 -25 psi on 91 what do you guys think ?
any suggestion ? need help guys !!!
Old Jun 3, 2009 | 12:34 AM
  #50237
bchappy's Avatar
^he knows what he is doing.
if he says do it, it is for a reason.
Some dont need injectors some do. Its a good Idea to do it IMO
Old Jun 3, 2009 | 12:43 AM
  #50238
GotWheelHop's Avatar
Originally Posted by Alan Szabo Jr
I had the extreme pressure plate with there 6 puck clutch last year when i had my 35r setup.... I would never buy that again. If you plan on driving your car every day get a twin. The ACT EPP is pretty damn tough. Your going to end up with a stronger left leg for sure!
+1
I had a ACT 2900 in my old DSM and it was a pretty hefty workout. The extreme pressure plate is rated at 3200 lbs of clamping force, and it takes a decent effort to work it. Sucks in traffic. Lol.
Old Jun 3, 2009 | 12:50 AM
  #50239
bchappy's Avatar
Originally Posted by GotWheelHop
+1
ya when I tried it in Alans car I was like holy
its a heavy kick!
Hey Eddie I need to get with you and disable this garbage EGR periphery....
Old Jun 3, 2009 | 09:25 AM
  #50240
SiCKlEyWiKeD's Avatar
Originally Posted by wesside
Manny what was the ix plugs you use with meth? And you don't gap em do you? I've got a friend up here who has a 30r on his ix with meth
Denso Iridium one step colder. IKH24 I believe. I used to order them from sparkplug.com
Old Jun 3, 2009 | 11:00 AM
  #50241
SinCityEvo9's Avatar
Originally Posted by McLaren F1 2003
i say get the xtss then, extra headroom...
unless you wanna go with a twin disc...
i had a new carbonetic twin disc ready for the car, but had to sell it (needed money at that time)......i could afford to buy another twin disc but people told me the act hdss setup was good enough for my plans.....i have swapped out alot of clutches on evo's already and i know the only one that holds up for the power is the twin disc but also breaks the bank acct .....
+1
thanks guys for the info.....i guess ill be buying the hdss pressure plate then.....
Old Jun 3, 2009 | 11:36 AM
  #50242
Alan Szabo Jr's Avatar
^^^ ya no problem... Plus the other thing that sucked about the ACT is they dont like to disengage after 8K rpm.
Old Jun 3, 2009 | 01:26 PM
  #50243
bchappy's Avatar
I really hate their pressure plates... I am not sure what is wrong with mine but the decel noise is ridiculous ever since I put it in...
Old Jun 3, 2009 | 02:29 PM
  #50244
McLaren F1 2003's Avatar
well arent twins noisy too?
Old Jun 3, 2009 | 02:42 PM
  #50245
Twins chatter at idle a lot. Just happens with the 2 free floating discs.
Old Jun 3, 2009 | 02:43 PM
  #50246
I have heard that the ACT clutches get lockout at high rpm as well, Alan.
Old Jun 3, 2009 | 03:43 PM
  #50247
It just needs to be adjusted is all. That's an old issue people used to have I personally really never had it with and of my ACT clutches and I had two of them.
Old Jun 3, 2009 | 06:48 PM
  #50248
i like the sound of a twin plate rattling
  #50249
nils's Avatar
it smells like corn in my garage!
Old Jun 3, 2009 | 07:57 PM
  #50250
twabtoxer's Avatar
my evo smells like mazola when at idle
