Las Vegas Evo's
Originally Posted by evo81
well,i'm f*cking fired up cause the cashflow will be coming in again,and the modding will start for the car again.
going all buschur this time around.should kickass.had a small set back,but i'm back on track again.
i'm thinking about getting buddyclubs 264/272 cams? i'm not the biggest combo fan,but i think i might try it. 264/264 was sweet,272/272 sounded cool but didn't work to well with the stock turbo.next choice is combo.might go 272/272 again cause it won't matter cause i'm getting an upgraded turbo also.hmmmm.....how do you like your combo set up IE?have you tried anything else???
Originally Posted by IE Evo
I hope to be there again. Car gets no money. Time to catch up John. I hope you get more go and less show this time around. Or I hope your show =your go. 10 sec car if that were the case.
f*cking assh*le
i'll show you.low 12s/high 11s
Hey I really have nothing to compare it to. However, word has it that you keep the good lowend with the 264 and get better topend with the 272.
i'm not even sure what i'll be shifting at with the kit.i'll like to get a smaller kit so i can get into auto-x also.i don't think the 272 across the board will be good for that.i'm even thinking about 264s str8 up.
way ahead of you on that one.BB is the only way
Actually the speeds you are used to going Autox is your calling.
Autox = Stock turbo or the bR 440 and 264 cams .
but the only problem is,that i'll be at the drag strip more than the autox course.i'm trying to find a common ground for both.
