Las Vegas Evo's
Originally Posted by joEvo8
I dont want to spend the excess money for a aftermarket clutch when my clutch is still pretty good.. Its grabbing and holding all that power. but once i hit 11s.. I'm done for the track and I'll just be saving up cash and tear & wear on the car..
Originally Posted by evo81
get an rre no name.the stock clutch will cost around 400 bucks.just spend the extra 100 for a better clutch.plus the rre one looks like the stock one in case you mess up you car,and want mitsu to check it out for you.i should of got the rre,but got an act.same thing.
Originally Posted by EvoallovEr
cusco+exedy=daikin, right? very similar products same manufacturer
Originally Posted by IE Evo
Doesn't that clutch lock u out of 4th gear John?
my next clutch in going to be an exedy twin i think.unless something else comes out on the market that kicks ***
Oh I guess I thought $$$ grew on Trees?? But Still trying to figure out to go with Cusco or Exedy.. ? If Cusco can handle IE's monster.. then I'm leaning towards that one.. I'm still going to run the Next MM with my current clutch... as long as I take car of it. like i usually do.. it should last..
yes. joe i would get the twin if you could also.i wish i spent like the extra 500 on one instead of going cheap with this act,which feel hard to shift in high rpms
yo IE- the 3071 that shiv is tuning has a bj intake manifold on it????i thought an aftermarket intake manifold couldn't run right on a stock maf?
I feel that besides Dynoflash that Clutch kept u out of the 12 sec club.
I think not. he has had that stupid BJs crap on his shop car forever. The 3071 is great pump gas turbo but Jon u will want more for sure.
it just is hard to shift with it.the stock was so much better.i could shift fast.i do like the hard pedal feel of an act.the soft pedal is werid now.everytime i hop into a stock clutch evo,i'm always like"is your clutch going out"
Yeah the Cusco will be softer than the Act pedal but as with any upgrade there are tradeoffs. The TwinClutches do allow you to shift faster and can be slipped at high rpms w/o a problem. Dumping a twin is a mistake and will cost u the front diff IMO
damn!i always wanted a magnus intake manifold but i always read that it's no good if your not on a stand alone.whatever.a intake manifold isn't really needed until your making some power anywayz
