SCLC archives
Old Aug 22, 2003 | 07:46 AM
  #1966
DEVOTED's Avatar
I think I'm going to wash my car and add a couple stickers which should drop my 1/4mile times by atleast 2 secs
btw whats up with the gas prices? What does arizona's fuel shortage have to do with CA? Do we get fuel from them?
Where do they sell race fuel in SFV??? I know it makes a little difference with turbos.... but would it help with our reflash, or just be a waste of money?
Old Aug 22, 2003 | 07:58 AM
  #1967
Guru_Del's Avatar
Rules about tomorrow:
Vehicle must have current vehicle registration, license and a valid proof of insurance (must have all documentation with you at time of registration). NEW FOR 2002 – Cars can be brought into the speedway on Trailers and approved racing slicks are permitted. All vehicles must enter off of Cherry Avenue. The speedway is located at 9300 Cherry Ave., Fontana. Cost - $10 per person to enter the speedway and $10 for a Tech Card to race your vehicle ($20 total).
Under 18: Anyone under 18 years of age must have a parental permission form completed and signed to race. If parent is not present on race day, the form must be notarized and submitted with registration materials. A new form must be completed on each race day. The form does not carry over from race day to race day!
10-Second Rule: There is a 10-second flat ET rule. No cars quicker than 10 seconds will be allowed. (If you need an NHRA Competition License to drive your car at an NHRA Drag Strip, it is too quick for California Dragway.)
Vehicle: no water, fuel, oil or trans leaks.
Electronics: No aftermarket electronic devices allowed (throttle stops, delay boxes, etc.)
Exhaust: Must be routed through street legal muffler(s). All runs will be monitored on a decibel meter (100db at 100’ from the strip). If it is too loud you will not be allowed to run. NO EXCEPTIONS! It is your responsibility.
Tires: Aprroved Racing Slicks are Permitted, as well as Street legal DOT approved treaded tires, front and rear required on all vehicles. Tires will be inspected for overall condition.
Wheels: All wheel studs, with lug nuts required. Broken or missing studs/lugs must be replaced before racing. Hub caps/wheel covers must be removed for inspection.
Lines & Hoses: All fuel, transmission, brake and power steering lines must be secure and free of leaks. Neoprene fuel lines limited to 12” overall.
Radiator: Overflow catch tank mandatory on all vehicles and no leaks.
Driver: Must have valid state driver’s license. No shorts, bare legs, tank-tops, bare torsos, bare feet permitted when racing. (Insurance requirement).
Helmet: Required in all vehicles faster than 13.99 seconds. Helmet must meet SNELL 90 (effective Jan. 02) or better standards (must have label inside of helmet).
Seats: Must be securely fastened to floor or frame with minimum 4 attaching bolt and nuts. No sheet metal screws.
Seat Belts: All cars and trucks must have as a minimum, an O.E.M.-type lap belt system, securely mounted to frame or floor.
Batteries & Ballast: Batteries must be secured per OEM, or with minimum of 2 (two), 3/8” diameter bolts (no straps, bungee cords, wire, etc.). Loose ballast is not permitted on the racetrack, so be prepared to empty trunks and interiors of all loose items. Spare tires, jacks, etc. must be securely mounted or must be removed. Tools, jack stands, coolers, loose speakers, wheel covers, etc. are considered loose ballast and are not permitted on the track. If you don’t need it, or don’t want to leave it unattended, leave it at home.
Neutral Safety Switch: All vehicles must be equipped with an operational Neutral Safety Switch. The neutral safety switch prevents the vehicle’s starter from turning the engine over unless the transmission is in Park or Neutral (or unless the clutch pedal is depressed with a manual transmission).
Nitrous Oxide: Bottles must be stamped as meeting DOT 1800-pound standards and must be securely bolted to the frame or floor (no bungee cords, hose clamps, etc). All fittings, hoses, etc. must be compatible from same manufacturer, vented to outside of driver compartment.
Roll Bars & Cages: Roll bar required in any vehicle running between 10:00 and 11:99 E.T. (convertibles between 11:00 and 13:99). Roll bar / cage structures must meet minimum NHRA standards as found in the 2002 rulebook.
Motorcycles: Must be registered for the street, front and rear brakes, chain guards, ignition cutoff switch, and functioning snapback throttle mandatory. Any pressurized container (air shifter bottles, nitrous bottles) must be stamped as DOT 1800-pound standards. Leather jacket, gloves and leather (above ankle) shoes mandatory (up to 120 mph; over this speed-full leather is required). Full-face helmet labeled as meeting SNELL 90 or better Mandatory.
Convertibles: All racers participating with convertibles that are quicker than 13.99 seconds MUST wear a helmet.
Note: When elapsed times are quicker than 11.99 specialized racing equipment is required. For example, when a roll bar or cage is required, so is an approved 5-point shoulder harness assembly. If you know or suspect that your vehicle will exceed these ET limits, we suggest contacting the NHRA Tech Department at (626) 914 4761 with your questions.
After Tech Inspection
Move your car forward and walk to the “Tech Registration Table” Where you will show I.D., sign a release of liability and get a wristband for restricted area access. Once you have completed registration, return to your car to have your number applied to your windows. You may now find yourself a “pit” location (10’ X 20’ max per car).
Hear the Call
Tune your car radio to 104.7 fm for the Speedway’s PA announcements. All categories will be called to the staging lanes at random rotation. Listen for your category to be called. Please DO NOT come to the lanes until your category is called. Be sure to bring your “RUN CARD” and have all safety items in place with seat belts on. Also, leave all loose items out of vehicle.
Rev it up
When you get to the back of the staging area, you will be directed to a lane. At the front of the lane you will be asked for your “RUN CARD”, get it punched and proceed as directed.
Burn – Out!!!
You will be directed to the “box”, where a 5 second burn – out is permitted. On the Starting Line Official’s signal, roll your car forward until the top two small yellow bulbs on your side of the christmas tree are lit… STOP. You are now STAGED and ready. When the tree is activated, you will see 3 amber bulbs flash ½ second apart then GREEN…GO!!! GO on the GREEN. Hint: Try to leave on the last amber for a better reaction time.
Top Speed…
After crossing the Finish Line, let off the gas slowly apply the brakes. Stay in your lane and drive to the end of the track, turn left and return to the pits, stopping at “TIME-SLIPS” booth. Return road speed limit is 15 MPH.
Quiet Please
In our continued efforts to be good neighbors, we will be enforcing our “zero tolerance” policy for decimeter readings over limit. Also, please be considerate of what our neighbors think of us when leaving the facility…Drive Safely
California Speedway reserves the right to deny participation and revoke all rights and privileges pertaining to this event.
No Alcoholic Beverages or Glass Containers are permitted on the premises.
Old Aug 22, 2003 | 08:19 AM
  #1968
Coolguy949's Avatar
I want to go!!! Team SoCalEvo baby!!
I'm now sure I can go yet......we'll see.
Old Aug 22, 2003 | 02:23 PM
  #1969
twinkiemobile's Avatar
Can someone tell me what time this event will be over?
Old Aug 22, 2003 | 03:01 PM
  #1970
1DVSOZ's Avatar
Whats up to all my socal friends this meet sounds sweet wish i could go. I was wondering if there will be any meets the weekend of sep13,14 I will be at my moms with the baby in lake elsanore and would love to come hang out and see some sweet *** lancers. let me know and have fun this weekend.
Old Aug 22, 2003 | 04:03 PM
  #1971
plastikpyro's Avatar
SCLC Meet #15 Saturday August 23
SCLC Convoy from Road///Race to the California Speedway.
People who plan to participate please arrive promptly at 8:30am.
Departure time is 9:00am.
Directions from Road///Race
1: LA DANA CT toward SHOEMAKER AVE. 0.01 miles
2: Turn RIGHT onto SHOEMAKER AVE. 0.19 miles
3: Turn LEFT onto FLORENCE AVE. 0.50 miles
4: Turn RIGHT onto BLOOMFIELD AVE. 0.44 miles
5: Turn LEFT onto TELEGRAPH RD. 1.64 miles
6: Merge onto I-605 N. 9.73 miles
7: Merge onto I-10 E. 30.12 miles
8: Take the CHERRY AVENUE exit. 0.23 miles
9: Turn LEFT onto CHERRY AVE. 1.31 miles
Total Estimated Time: 46 minutes Total Distance: 44.17 miles
Mapquest Link:
http://www.mapquest.com/directions/m...go=1&ct=NA&r=f
Fees:
20 dollars to drag
10 dollars to spectate
Bring your own food and beverages or pay the outrageous prices at the concession stands.
Rules for drag racing at the Speedway:
http://dbserver.iscmotorsports.com/C...lishment_ID=1&
www.sclc.net
www.roadracemotorsports.com
www.californiaspeedway.com
**SCLC CLUB EXCLUSIVE**
All SCLC members are elgible for a 10% discount on most Road///Race parts if purchased at the convoy. Bring CASH.
This offer excludes, ECU reflashes, Turbo kits, Throttle Bodies and non RRM in house parts.
Old Aug 22, 2003 | 04:44 PM
  #1972
Coolguy949's Avatar
Isn't there a 76 station that sells 100 octane near the track? If not i'll have to stop in newport beach and put 5 gals in...
If I go, that is...
Old Aug 22, 2003 | 05:30 PM
  #1973
topsnwbrdr's Avatar
Angry Grrr!!!
OT but some f'er almost hit me head on today!!! Do you know how pissed I would have been if I couldn't make it tomorrow because some ahole can't drive. Anywayz I got my car wash and now have all the interior parts back for my car. So I just need some gas and im good to go for tomorrow. Gonna be a great day.
Also how late are some people staying? Just curious
Old Aug 22, 2003 | 07:40 PM
  #1974
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I think the Unocal 76 station in Agoura (off Kanan) still sells race fuel, but a reflash NA car would run just as fine on 91 as it would on 100, as per my conversation with Rob last weekend. Besides, with these gas prices, even sticking with the 91 is going out of my budget.
To address some other questions:
The drags go on until 11pm, but you and/or we can leave any time we want to.
Boe, it looks like you will need a helmet. I will be bringing 2 legal helmets, size S and size M if anyone needs them (aka the turbo people)
Old Aug 22, 2003 | 07:44 PM
  #1975
Moderator
Bomb Squad Unit #02
One more important announcement, we will be taking applications at the meet. Remember that you must be paid by September 1 to be a founding member. If you want your membership card to be ready when you hand in your payment tomorrow, you'd best PM me in the next few hours so I can print them, otherwise you will have to get it at the September meet.
If my records are correct, I have applications but no payment yet from Chris Holman, Ryan Realivasquez, and Adam Johnson. All others paid by now will get their cards handed to them tomorrow.
Old Aug 22, 2003 | 09:15 PM
  #1976
DragonLancer's Avatar
geez i can't wait to go, eh my friend mike's making me race tho... o well, i hope i git to race next to a scion that way i seem a lot faster
Old Aug 22, 2003 | 09:52 PM
  #1977
Link286XT's Avatar
hey brian dont forget to print one up for me too, i'll pick it up eventually, hehe
Link
Old Aug 22, 2003 | 10:14 PM
  #1978
ROCK's Avatar
Save your money Urban. Just run 91 octane. See everyone tomorrow. Come early to our shop if you want something. 10% off sale for SCLC!
ROAD/RACE
http://www.roadracemotorsports.com/
Old Aug 22, 2003 | 10:58 PM
  #1979
apexlancer821's Avatar
what time is everyone going to get to the speedway? i'm go do some OT at work till 12 so you guys think any1s still going to be there?
Old Aug 22, 2003 | 11:27 PM
  #1980
Moderator
Bomb Squad Unit #02
if you mean 12 noon, we'll definitely still be there, if you mean midnight, not a chance in hell!
