Buying an evo
Old Dec 19, 2009 | 07:02 PM
Endless AWD's Avatar
Question Buying an evo
Does anyone know anything about this Evo. Or anything about the dealer. Any information would be helpful. I live in Washington and only want to make one trip down there to buy it. It appears to be exactly what I'm looking for so I'm willing to make the trip.
http://edmunds.autotrader.com/fyc/vd...standard=false
Thanks in advance.
Old Dec 19, 2009 | 10:40 PM
MR_Evo206's Avatar
that's a nice find! i am from Seattle thinking about going to Cali too. Sad huh nothing at all in our area...
Old Dec 20, 2009 | 02:08 AM
ya pretty much. I've been looking all over the country for something. Its ridiculous.
Old Dec 20, 2009 | 11:39 AM
MR_Evo206's Avatar
good luck!
dude i hear you man! i hate it, it really sucks over here in Seattle. I have found NOTHING.....i'm considering even flying down to San Diego to just buy a car.....anyways good luck on your search, i have been looking for almost a year and a half now...
Old Dec 20, 2009 | 11:49 AM
erald01's Avatar
yeah i would stay away from a dealer car, personally i just dont like how the cars are way over priced for what they buy them for, and if something is wrong with the car they will do a temp fix just so it passes the test drive, plus 24k its way too much for an 06, yeah it has low milage but there is plenty of cars for sale on the forum and way cheaper, and you can see the history of the car or owner through the forum, but good luck though
Old Dec 20, 2009 | 11:51 AM
rayman0690's Avatar
Looks nice, only thing I see is an HKS intake on it. But it looks nice, my only advice with my recent struggles is do some reading on HVAC controls for the Evo and then get up under the footwell on driver side and check gears/levers. Also turn knobs on the HVAC and see if any binding or struggle occurs. If so, have some money back to fix it.
Old Dec 21, 2009 | 02:02 AM
Ya a dealer wouldn't be my first choice but i have a limited window of time to buy a car and am also very picky so I'm resorting here. Definitely going to have it fully gone over by a seperate mechanic to make sure there is nothing wrong.
Thanks for that I'm gonna make sure to do that now. and what gears and levers would you suggest checking and for what? Any other problem areas to look at? I know I'm going to listen for T-case whine and check that there aren't many more mods.
Old Dec 21, 2009 | 07:55 PM
rayman0690's Avatar
@ EndlessAWD
Check this thread out, the first post, look at the picture he posted.
https://www.evolutionm.net/forums/ev...n-problem.html
You want to make sure when you crawl under there that you have the levers that are pictured on the left, not the ones that are on the right. Otherwise carefully test out the controls for the HVAC for binding or any spot that has resistance. You DON'T want to have to yank left or right or you will break something.
Keep reading in that thread to understand a little more about the issues. It plagues Lancers and there are multiple "recall-ish" notices about how to repair it. If you have anymore questions on that let me know. I'm slowly becoming an expert on it.
This is what happens when you don't know about the HVAC issue, and have a major issue that isn't solved by the minor fixes for the HVAC controls:
http://www.facebook.com/album.php?ai...7&l=e6db270218
Old Dec 22, 2009 | 03:35 PM
Thanks for the advice. Ill make sure I check on that.
Old Dec 22, 2009 | 03:41 PM
Ryan.Kauz's Avatar
in picture 12 you can see all three ACD lights are on while at idle. That is a bad sign. in my case I thought a simple ACD fluid flush would fix it, turns out it was the ACD pump that needed replacement ($2,300)
It will be covered under the 60K warranty unless its been voided by mitsubishi..... I'd call a dealership with that vin and ask if there are restrictions on warranty work (they should be able to tell you that if your not the owner).
Old Dec 22, 2009 | 03:55 PM
Kevin.'s Avatar
hahaha wow nice eye!
Old Dec 22, 2009 | 04:18 PM
Ryan.Kauz's Avatar
^^ get screwed once, you tend to look out for these things! if it was at ignition stage 2 then no worries. but at idle it should be only a single light.
Old Dec 23, 2009 | 01:33 AM
O well thank you for spotting that. if there is a problem with that, that could save me a lot of time. but ya im calling to check on the warrenty in the morning. like before good eye.
Old Dec 27, 2009 | 09:11 PM
MR_Evo206's Avatar
how's your search going so far?
Old Dec 27, 2009 | 09:19 PM
fcapistran's Avatar
You don't like this
http://seattle.craigslist.org/tac/cto/1524564653.html
http://seattle.craigslist.org/sno/cto/1521986968.html
