Works 3" O2 housing rumor's?
Im skeptical on a first run production for this item...ive seen several manufatures produce uneven surface's on the o2 housing (from the turbine housing to o2 housing mating point)
Are your's guarenteed from defect?
After the piece is cast, the flanges will be machined flat. Structurally, the cast piece will be MUCH stronger compared to a welded tubular piece because there is much more material. Cast is the only way to go for an o2 housing IMO.
Well said Mark
WORKS is scrutinizing every little detail of the housing to ensure proper fitment and performance. Rest assured that it won't be released until we're 100% satisfied.
Originally Posted by carbonevo8
any new news yet guys im dying to know also will it fit a helix downpipe. thanks
Originally Posted by Evo23IG
Does the design of your O2 housing incorporate the bolt on side of ther housing like the stock one???
This housing may not fit other brand downpipes. If your downpipe uses the stock donut gasket, chances are that you will need to upgrade to a true 3" Downpipe from WORKS.
Thats good to hear, but it sucks I have a Perrin downpipe already coated and been mounted for almost a year now. Finally a O2 housing that has the bolt on the side like the stock one, wow, this really makes me want this. I really would like see the gains of this product before I buy it though (dyno sheets). I definately got to give a
a for a quality part. I will be looking forward to the data.
