WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
Works Exhale DP Questions
Old Nov 18, 2004 | 10:18 PM
marksae's Avatar
I'll be installing my WORKS HFC this weekend. I'll post some pics too! The WORKS HFC is one quality piece!
Old Nov 20, 2004 | 06:54 PM
garrick70's Avatar
Here are those pics!! Works HFC and DP
Pretty cool, eh?
Old Nov 20, 2004 | 07:36 PM
b18flip's Avatar
does the 76mm works dp bolt up to the MR edition??
Old Nov 21, 2004 | 12:43 AM
jbigelow's Avatar
Nice!!! Very Nice!!!!!!!!!!!
Old Nov 21, 2004 | 12:47 AM
marksae's Avatar
Here's a picture of mine installed:
Old Nov 21, 2004 | 09:17 AM
garrick70's Avatar
O.K. I have a question. When I called and talked to Tyler he said that I needed to have the writing "for off-road use only" facing the car. However, Marksae has his writing facing down. Which way is correct??
Old Nov 21, 2004 | 09:22 AM
marksae's Avatar
According to the instructions, the heat shield should be "towards the vehicle". I did notice very tight clearance between the cat and heat shield though. But I don't have any rattling issues.
Old Nov 21, 2004 | 11:39 PM
Alias's Avatar
Agreed! The instructions did say to make sure the heat shield is towards the vehicle. I install mines with the heat shield towards the vehicle. That makes the "off road only" words visible. As I recall, I also saw a pic either posted by WORKS or someone else that had the "off road only" words facing down.
Old Nov 22, 2004 | 12:21 AM
jstockdale's Avatar
As I understand it, the cat can be mounted either way. Technically/legally it should be mounted with "Off Road Use Only" to the ground (so it's visible on inspection) and that's WORKS official position (hence the installation instructions).
However, this is only because it's not certified for street legal sale at the moment.
From an operational standpoint, the cat will function the same if the marking is facing the car. Of course, that means if somone mounted the HFC on a street car (which I'm sure no person on the boards would do) it would not be noticed as a Racing Program piece on inspection (ie. if a cop stopped them or if they smogged their car).
-S ...
Old Nov 22, 2004 | 03:26 PM
Jamie@WORKS's Avatar
Absolutely! We have it on the WORKS MR right now. We do recommend the ceramic coating to keep the heat away from the ACD and other drivetrain components.
Old Nov 22, 2004 | 03:28 PM
There is only a slight variation in the heat shield depending on which way you mount it. WORKS has intended the lettering to face down as per the instructions. I (like Garrick) have mine mounted with the lettering facing up--1100 miles and no worries here
Old Nov 22, 2004 | 03:48 PM
ivanko's Avatar
It will work as I recently installed the 76mm dp on my EVO 7 RS which has the ACD system.
Beautiful craftsmanship, fitment!
Adam
Old Nov 22, 2004 | 05:25 PM
garrick70's Avatar
Thanks Jamie, I called again tonight and Tyler told me that it should have the lettering facing the car. So, i am going to assume that either way is fine since you have yours mounted the same way.
Old Nov 22, 2004 | 09:47 PM
marksae's Avatar
Does mounting it w/ the letters facing up give more clearance between the cat and the adjacent heat shield?
Old Nov 30, 2004 | 11:19 AM
garrick70's Avatar
Hey Mark, It did give me a little more clearance, but I have flipped it over since I took those pics, and have not had any rubbing issues with it set like yours.
