WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
CEL fix?
Old Apr 19, 2005 | 08:18 PM
Compjoc's Avatar
CEL fix?
Does Works offer a Check Engine Light fix by reflash for test pipes or EGR removal?
I'd love to get rid of the EGR system to clean up my engine compartment but from what i read, there is no fix for the CEL it will cause. And CEL's bug the hell out of me. I have a mechanical fix for my test pipe but a reflash would of been much easier.
Old Apr 20, 2005 | 12:03 PM
Jamie@WORKS's Avatar
We are currently working on the CEL. This is the first request for the EGR though.
Old Oct 23, 2005 | 01:00 AM
Compjoc's Avatar
Any updates?
Old Oct 23, 2005 | 01:03 AM
mitsuorder's Avatar
I think the egr removal would be interesting...
Old Oct 26, 2005 | 04:46 PM
Originally Posted by Compjoc
Any updates?
None at the moment. SEMA, Time Attack and the release of the IX have us swamped. It's going to be at least another month before we persue things further.
Old Oct 26, 2005 | 04:49 PM
nutrulz's Avatar
What would be the advantage of EGR removal? Noob question?
Old Mar 10, 2006 | 02:11 PM
overdrive's Avatar
Is there a flash to fix the rear O2 CEL yet?
Old Apr 5, 2006 | 11:55 AM
ovenmit331's Avatar
bump
Old Apr 6, 2006 | 06:21 AM
EvoG8r's Avatar
Just do the mechanical o2 fix. Get 2 spark plug antifoulers (Brand: Help! PN 42009) and drill a 1/2" hole in one. You essentially screw the one with the small whole into the bung first. Then the one with the hole you drilled, followed by the 02 sensor. This will get it far enough from the path (but not too far!) of the exhaust to remove the check engine light. Do some google searches and you will see it. You will also see some on ebay.
Old Apr 10, 2006 | 09:03 AM
lowkey's Avatar
Registered User
Look here:
https://www.evolutionm.net/forums/sh...59#post2984459
Old Apr 10, 2006 | 11:17 AM
ovenmit331's Avatar
anyone know if just one anti-fouler will work? so i don't have to take a hammer to the underside of the car! i may just try it and see...
also (semi OT), a friend of mine told me that not having a cat will mean i'll have to replace my exhaust within the next three years. something about the exhaust being eaten through or basically rotted away. I'm 99% sure that he's just dumb, but i thought i'd make sure.
Old Apr 10, 2006 | 12:16 PM
Compjoc's Avatar
It might work, you should give it a shot. I'm running the double anti-foulers and they've worked perfect for the last 5k miles. I'd still love to have a flash that would disable the CEL. It would be nice to get rid of the anti-foulers or maybe the rear o2 sensor all together.
Old Apr 10, 2006 | 03:49 PM
lowkey's Avatar
Registered User
Even with just one it's kind of tight. You might want to try the two kinds, the 42002 is slightly longer than the 42009. If you use just one, the longer one probably has a better chance of fixing the CEL.
The hammer work sounds worse than it is. It made a nice indentation on the side of the transmission tunnel and a slight bump under the carpet and passenger seat.
As for stainless steel rotting / rusting... don't think so - it will probably outlast the car.
Old Apr 11, 2006 | 09:09 AM
ovenmit331's Avatar
I bought a different brand and we'll see how it works out... if not, the hammer will have to do.
as for stainless steel, thats what i thought.
