WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
HFC and check engine light
Old Sep 17, 2005 | 02:04 AM
  #31
simevo's Avatar
I have the Helix HF cat. It worked fine for 8k miles then after adding intake and some other mods, SES light pops up. Not sure if mods cause HF cats to throw SES or the cat just can't do it's job anymore. It seems like I'm getting random P0420 just like the P0300 code some people are having.
Maybe Works can program the P2 to ignore the P420 code or figure out why only some Evo's with HF cat throw SES.
Old Sep 17, 2005 | 05:03 AM
  #32
justchil's Avatar
I'm stilll doing great with the mechanical fix with 2 anti foulers. I've put about 5k miles on with no light. I've got a test pipe now and still no light on
Old Sep 17, 2005 | 02:39 PM
  #33
Alias's Avatar
Well, on the WRP Brain Flash RL on WORKS website, here is what they said:
-Factory RPM limit
-Boost/fuel cut limit (This is the actual map where we can set a hard ceiling. We are not merely delaying the grace period which can cause catastrophic failure)
-Two stage rev limiter ('05 available now, '03-'04 coming soon)
-Rear O2 sensor defeat (coming soon)
So it seems that they are trying to come up with the flash to defeat that. Hopefully soon, but we all know what "soon" really means. Still, I do appreciate how WORKS does spend the time to ensure that their product is safe and proven even if it takes a bit longer for the product to come out.
Old Sep 17, 2005 | 04:35 PM
  #34
PA-silver03evo's Avatar
I got a CEL from my Ultimate Racing HFC but the way I see it, thats a good thing because that means its flowing a lot more than stock. I used one anti fouler cause I didnt have room for 2 and that took care of the light.
Old Sep 18, 2005 | 10:22 PM
  #35
nj1266's Avatar
My UR HFC came with the CEL fix Plug since I ordered a an LPI test pipe along with the HFC. The anti-fouler plug is the long type and it fits perfectly in my mid pipe. I installed the HFC, the JIC dp and the Invidia cat-back and I have no CEL yet.
Old Sep 19, 2005 | 06:26 PM
  #36
Jamie@WORKS's Avatar
The WORKS HFC is intended to be a fully functional catalytic converter. We did several thousands of miles of testing with a few different designs before committing to this one. I know I've got over 16K on mine without seeing the P0420 and a few of our customers have significantly more miles on theirs.
Old Sep 19, 2005 | 06:42 PM
  #37
Spec'd's Avatar
Jamie, what about some of the Evo owners experiencing a CEL with the
WORKS HFC ?
Just to let you know, I have a couple of other WORKS products on my Evo.
Old Sep 19, 2005 | 07:07 PM
  #38
Honestly, I can't explain it without knowing some more info--mods, type(s) of fuel used, miles, etc...
Old Sep 19, 2005 | 07:13 PM
  #39
Spec'd's Avatar
Yes I see your point.
Old Sep 19, 2005 | 07:47 PM
  #40
nebolic's Avatar
I am almost at 40K miles with my Evo, no cel yet except the p0300. WORKS HFC is working great.
nebo
Old Sep 19, 2005 | 07:49 PM
  #41
Curt@MrLed's Avatar
Former Vendor
buy the screw in fix for the 02.. i have 3 inch pipe turbo back.. and no cel..
Old Sep 19, 2005 | 08:24 PM
  #42
inariv5573's Avatar
That's actually a bad thing because the cat isn't doing its job. You may not pass emissions. You might as well buy a test pipe.
Old Sep 20, 2005 | 03:13 PM
  #43
Alias's Avatar
nebo
How many miles do you actually have on the HFC?
Old Sep 20, 2005 | 04:39 PM
  #44
vtluu's Avatar
I've had about 20k miles on my HFC, and no cat-related SES lights. (Just a big pile o' P0300 codes.)
Old Sep 20, 2005 | 04:56 PM
  #45
dohcvtec's Avatar
I have the Works HFC and have never had a CEL, putting around 15,000 miles on it. Lately my friend "got boost" has been getting them with his Works HFC. He has the works DP, and cat back also.. along with GFB BOV and 272 cams, stock ecu. Seems like this is only happening to some people.
