How far can you revv?
you can rev as far as you rev limiter is set =).
how far do you want to rev with your current setup? we dont know, cause we dont have your current setup.
depends on your parts, and your tune, and your plans / goals, and a few other things. give more info and we may help!
We usually bump the rev-limiter to 8,000 RPMs with the WORKS V-Springs and Ti-Retainers. You could go beyond that, but I would suggest building up the bottom end before doing so.
Yea thats around the highest i went, just want to make sure before i float a valve. Thats what i got, the works valvetrain and cosi cams, what do you think the highest i can go on stock valves? Also is it not safe to go past 8k on stock bottom end? Thanks for all the help
launch control is SET AT 6100 RPM, and rev limit is set at 7,800.
AMS DBB 50 TRIM 21 PSI 92 Octane
car is stock motor (HKS264/272 cams)
3" Titanium TurboBack
AMS FMIC, LICP, STOCK UICP
EXEDY TWin being installed friday.
ApexSilverXGSR
Nov 8, 2009 06:54 PM
i love my two step
