04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Dirtyralli's turbo build
Old Jun 8, 2016, 12:49 AM
CrAnSwIcK's Avatar
GT28 should be ok, too much bigger and it won't be as fun to drive stop sign to stop sign, if you know what I mean, I sent you a huge PM...for the manifold...I would look at getting something as close as possible to the RPW manifold...kind of a log/mini-ramhorn hybrid...keeps the turbo nice and high for a good oil scavenge like a log, but has more efficient flow. Josh is right about the size...it is tight...I still run a stock rad, with stock fans, and good luck reaching your hand down there...when we finally meet, you'll see what I mean...there are turbo options out there that have bigger compressor wheels in smaller housings...like my 20g is in a big 16g housing...I would also go with a turbo that could accommodate an external wastegate, with the charge outlet facing downward, regardless of whether you think you're going internal or external, give yourself the option...again, when you see my setup in person, you'll be like, "WTF?" It's really annoying to work on. changing the starter means taking almost the entire turbo kit out...and the middle exhaust nut is almost impossible to get at, so I leave it off.
I should have kept my blown-up block, I have a mig welder now, so I could have mocked up some manifold designs...I have the head, and a spare transmission case I could have used for starter and clutch slave clearance.
Old Jun 8, 2016, 03:46 AM
DirtyRalli's Avatar
Yeah i dont think ill go any bigger than a gt28, and that turbo is internally wastegated that was the only downfall because it is an oem replacement for a r34. Yeah we dont have much room in there and like josh said i might have to go with a half rad because i do have an aftermarket rad right now. You could have fabbed up manifolds for everybody for cheaper lol!
Old Jun 8, 2016, 07:44 AM
CrAnSwIcK's Avatar
If I had a tig welder, and was any good at it, I would for sure...if I had stock exhaust still, I could even build a downpipe...mig can be messy and it's hard to weld the inside of very acute angles, and tight spaces...tig is like soldering, you can feed your filler from a different angle than the welder, and the tips are thinner.
Old Jun 9, 2016, 08:06 AM
mnunez2's Avatar
Originally Posted by bakuro117
I dont really have any specific turbos in mind for you. But I will say this: Be careful about what you go with. There is a lot less room than you think for placement if your going with the standard location. In all seriousness on the RA platform if your wanting a properly sized turbo I would go with a halfsize radiator, or at the very least get a pusher fan setup from an Evo and ditch the passenger side fan on the back of the radiator. You have an aftermarket rad too if I remember correctly. So your going to have even less space to work with.
A halfsize radiator works well like the original (RA or evo) full size radiator?
Old Jun 9, 2016, 08:31 AM
bakuro117's Avatar
Yea they work fine. Lots of Evo guys run them. I ran one in a 3g eclipse. I have another one I am putting into a mirage someday. They work because they are nearly twice as thick as the RA or Evo's stock radiator. Just make sure you use a good fan and you should have nothing to worry about.
mnunez2 (Jun 9, 2016)
Old Jun 9, 2016, 09:50 AM
mnunez2's Avatar
And there is no problem with the A/C taking out the fan of the A/C system???
I really don't have clear the function of that fan (of the A/C)... if it cooled the water on the radiator or cooled the A/C compressor... obviously the water on the radiator is cooler with that fan but the compressor don't need it?
Old Jun 9, 2016, 10:47 AM
bakuro117's Avatar
Most Evo guys either get rid of the AC or switch to a civic condenser if they want to keep it. If your keeping the stock condenser I would get a slim fan and wire it up to the stock connector for that fan. Or, the stock fans split in two down the middle IIRC. Maybe there would be a way to attack the stock fan to the condenser.
Old Jun 10, 2016, 03:41 AM
DirtyRalli's Avatar
Is it alot of work to remove the AC because im considering it? Does it just consist of putting a dead pulley?
Old Jun 10, 2016, 06:29 AM
bakuro117's Avatar
worst part about removing the AC is if you break off one of the bolts holding the compressor on. I did that on my eclipse once.
You can get a shorter belt (cant remember the size) and remove the entire pulley from the loop. Remove the high and low pressure lines from the compressor. Remove the 4 bolts that hold it to it's bracket and drop off the compressor. You'll have to remove the radiator to get the condenser out. Then I think there is one bolt that connects the high and low pressure lines to the firewall behind the engine. Once the lines are gone you can find block off plates online to cover the holes in the firewall if you want, or just fab something up.
Old Jun 12, 2016, 09:51 PM
CrAnSwIcK's Avatar
I bypassed my compressor when the pulley seized up...I think the belt I used was 60 inches.
Old Sep 26, 2016, 06:17 PM
SilentCool's Avatar
Great news, I'm looking forward to this turbo build. Always liked this car. It's one of my favorites on here
DirtyRalli
94
Jun 14, 2021 05:32 PM
DirtyRalli
Past Winners / Entries
Aug 3, 2014 01:38 PM
WickedIXMR
67
Mar 13, 2009 01:43 PM
turboj
19
Aug 9, 2007 11:26 AM
djskyy
13
Jun 11, 2006 10:21 AM
Quick Reply: Dirtyralli's turbo build
