2006 Ralliart 2.4l 06 Eclipse 2.4l
Are These Two Engines The Exact Same? Same Drivetrain I.e. Clutch And Flywheel Etc...? Thank You For Any Help, This Will Help End An Argument Here At Work
I don't know about exactly the same. You could cross reference part numbers to see if the Eclipse clutch is the same as the Ralliart clutch. But both will fit on the other's engine. The flywheels should be the same. Parts from both are interchangeable with each other but might have slight variations from one another and mean different part numbers. An aftermarket clutch kit for either will be the same and the same goes for an aftermarket flywheel. They are both 4G69 engines.
Example... The Lancer 4G94 engine and Mirage 4G93 engine have different clutches but an aftermarket flywheel and clutch for the Mirage will fit the Lancer engine.
Registered User
this is the eclipse gs we're talking about, right?
i test drove one when i was getting an oil change done, the clutch and shifter felt much lighter than the RA's, i could almost just tap the shifter into gear.
I drove the eclips when it first came out. I wouldn't buy one. I could tell that it felt heavier before I even heard that it was. And it was just uncomfortable to drive. I'm about 6'2" 210lbs and I could get in and out but not as easy.
yeah my friend has an 07 eclipse gs and i have the 04 RA....we were racing to a show(as in concert not a car show) from our job at best buy. i could hit corners harder and faster not to mention my acceleration PWNT his
again why paying less for something can benefit
not to mention he has a total chick car
