AEM EMS Get tuning help for your AEM EMS system.
Can't connect aem to my laptop
Old Oct 14, 2012, 11:24 AM
real fast's Avatar
I been into dsm's for 10 years and have tuned dsmlink v2 - v3 and was pretty good a it ..My 1g went 10.4@139) with me tuning it never been on a dyno all street tuned ... I just bought a 2005 evo 8 (built 2.1 destrocked) with aem serial 1313 and want to learn alittle about it ..I can't connect my laptop to aem to get the ball rolling ..This is the code its giving me
Cannot find USB communication library aemusb.dll
Serial to usb adaptor is keyspan
Old Oct 15, 2012, 09:05 AM
browningderek's Avatar
Open arm pro. Select cancel then offline. Go to file, connection port. A box will open. Select your cable from the drop down menu. If your cable name does not appear then you have cable/driver problems.
Old Oct 15, 2012, 09:35 AM
yenny's Avatar
I use aem pro v1.0. It didn't connect for me at first either. I had to play with the port settings under the serial option. Once I selected the correct port, it linked up fine
Old Oct 15, 2012, 08:56 PM
real fast's Avatar
Thanks guys I was able to finally get online; I was able to connect via the serial drop down option once I updated the drivers, but I'm now getting these two messages:
1.When I click "ECU Connect (Shift+F7)" I get the the error message which is picture #1 (aem 1).
2.Then when I click "New Calibration (Shift+F8)", I get the second error message which is the 2nd pic (aem 2), where it says exactly" "No installation for ECU type 'AEM15GEN version VTTRX'
This is all under AEMPro.... although there is also a "EMS Calibration" file with a .VTTRX extension, which also can automatically open AEMPro.
(But I cannot find any 'AEM15GEN version VTTRX' in any of the folders.)
I believe the old tuner must of put some kind of a lock because on either option above to open AEMPRo (or clicking the .VTTRX extension file) and get the files running, I just get those two error messages.
Even when I click under "Configure" to "ECU Setup" to "Run ECU Setup Wizard", I get a message that also says "Could not find AEM Configuration File. Please Call AEM for Assistance". Vehicle configuration Wizard "manufacture" drop down option is blank.
Lastly, I tried to "select new file type", and there's a whole list of options under "AEM15GEN", ranging from V0.22 to V1.21
I was doing a third gear pull and after 5500 RPMS, my wideband went to 12.3.
I would like to add some fuel to the upper RPMS and I would like to monitor the knock if any.
Any additional help or pointers is greatly appreciated.
Attached Thumbnails Can't connect aem to my laptop-aem-1.jpg   Can't connect aem to my laptop-aem-2.jpg
Old Oct 16, 2012, 06:05 AM
yenny's Avatar
^^ not sure of the answer to that. you may be right in that the previous tuner may have locked it. Hopefully someone can help you out
Old Oct 16, 2012, 06:05 PM
kreionic's Avatar
It's locked via turbo trix in jersey.
You may get lucky and they might give you a stock cal unlocked or your going to have to send it in to aem to wipe clean. No way around it at all unless you have that file that turbo trix uses which you won't get. Like I said you may get lucky and will send you a base cal that's unlocked
Old Oct 16, 2012, 07:28 PM
TheBoz's Avatar
Uninstall AEM Pro, and Serial to USB Drivers. Reboot laptop. Reinstall Serial to USB Drivers, reinstall AEM Pro, reboot.
Turn your car to ACC, and try to connect.
If you cannot connect still, it could be a non compatibal serial to usb driver.
Series 1 ECU's cannot be password protected, that only exists on the series 2.
Old Oct 16, 2012, 09:11 PM
real fast's Avatar
Ok thanks I will try my old top which has a serial connection but screen blinks and battery only works while pluged in ..Atleast I will cancel the usb to serial problem if there is one ...series 2 is nice cause it has a usb plus no pita usb to serial plugs needed.
Old Oct 16, 2012, 10:02 PM
I heard of someone hacking aempro and locking it. I never seen one in person though. The errors you are getting I have never gotten before.
Old Oct 17, 2012, 09:26 AM
99EclipseGSX's Avatar
This. "VTTRX" is a hacked firmware. The unit will have to be hard-reflashed by AEM Electronics. You can call 310.484.2322 x303 for Tech Support to request an RMA.
Old Oct 17, 2012, 01:47 PM
TheBoz's Avatar
Wow I have never heard of that, but here it is on the AEM Forums.
http://forum.aempower.com/forum/index.php?topic=28605.0
Old Oct 17, 2012, 01:50 PM
TheBoz's Avatar
Here is what JR from TT said on the subie forums.
He will unlock it if you take it back to him.
http://forums.nasioc.com/forums/show...54&postcount=3
Old Oct 18, 2012, 03:11 PM
real fast's Avatar
Thanks guys you were right..It had a lock but the previous owner was able to show me what needs to be done to unlock it ..Now I have to learn how to tune or at least log ..This is alot harder then dsmlink ;-()~
Old Oct 10, 2016, 09:51 AM
Jhova5's Avatar
I'm haveing the same problem I was hopeing you could help me out thanks
Old Nov 15, 2017, 09:06 AM
Jarrus Steele's Avatar
You need the USB-RS232 USB to serial driver. Do a google search, you'll find tons of them. Make sure it's the right driver for your OS.
Evorange
Sep 16, 2019 08:18 PM
SnailSpeed
Jul 23, 2017 12:35 AM
UxC
Dec 19, 2016 08:43 AM
SlickDude
Mar 11, 2016 04:37 PM
Quick Reply: Can't connect aem to my laptop
